Index > Engine/Drivetrain > Thread: s4 front cover with what omp?
lvmckane
efi progression
posted April 08, 2011 11:58 AM
ok so im going to be installing an 86's engine in the repu im in the midst of swapping the front covers. i noticed that the omp mounts are different. i understand that the s4 engine has 4 oil injectors and the carbed repu has only 2. obviously i want to stick with the s4 omp so it is to my understanding that i need to drill tap another mounting hole for the s4 omp?
sevenstock 14 or bust!
        Click here to visit lvmckane's homepage.
posted April 08, 2011 03:12 PM
GSL-SE
A GSL-SE front cover has the correct mounting holes for the omp you desire to use. Or you can block it off and premix.
paulsrepu
posted April 08, 2011 08:28 PM
Or, you can just drill and tap new holes in your original front cover. I did this 9 years ago when I put in a 87 Turbo engine. No problems at all.
lvmckane
efi progression
posted April 09, 2011 12:10 AM
great!! good to know. i was more worried about that very issue. drill and tap.. done but will it fit with no issues... thanks for the help, hopefully i can get this engine installed this weekend!!
0.018584012985229 seconds processing time
