Index > Engine/Drivetrain > Thread: 13 efi excess removal
lvmckane
efi progression
posted March 13, 2011 10:38 PM
ok so im planning on dropping an 86 13b n/a into my repu. i know that i must swap the oil pan and front cover. my main goal for the moment is to figure out what needs to stay and what i can block off/remove. this is going to be (for now) a 'completely' stock setup for the repu.
also other input and reminders are helpful too!
thanks!
        Click here to visit lvmckane's homepage.
gysgtfrank
posted March 14, 2011 04:30 PM
I'm trying to do the same swap on my 79 RX7 S model. I'll be interested to hear what others have run into on this swap to the early vehicles. I know it would be a lot easier if you stayed with the carburetion, but the EFI is awfully tempting. Especially when you have all the stock parts.
1979 RX7 S Model
1975 yellow&black REPU-sold
lvmckane
efi progression
posted March 14, 2011 05:32 PM
i recently pulled an engine with all i would need to 'drop' it right in... at least i think so. harness, ecu, coils, an engine and such... all stock of course. im pretty sure that i can block off the egr, and the acv, but im wondering if i need all those vacuums on a stock configuration? what else can i eliminate? so basically less junk more engine! who doesn't want that? :)
gysgtfrank
posted March 14, 2011 05:50 PM
I agree the less excess junk in the way the better. I'm not sure what can be safely eliminated either, which is why I am so interested in your post. I'm sure somebody has the knowledge out there. I haven't picked up my donor car yet, supposedly some of the emissions has already been eliminated, we'll have to see. I do know that the 6 port secondaries are activated by exhaust backpressure on the 86 & 87 engines. The 88 and later use the air pump, so it should be safe to eliminate that system on your 86. It sounds like we'll be doing about the same thing, my donor is an 87. Great minds think alike? Or maybe misery loves company.
1979 RX7 S Model
lvmckane
efi progression
posted March 14, 2011 06:11 PM
Edited By: lvmckane on 14 Mar 2011 18:13
the next step up in reliability from carburetion is EFI. at least in my mind. my main goal is just getting her on the road again, and tweaking her later!!
gysgtfrank
posted March 14, 2011 11:56 PM
By eliminating the system, I meant the air pump, not the secondary/6 port. You need that most definitely. The fact that the 86, 87 used backpressure to activate these ports is one of the bennies of using these years.
1979 RX7 S Model
spokanerxdude
Less cubes... More balls
posted March 30, 2011 06:22 AM
Here is a link that should have all the answers you need about both the secondary ports and the rats nest under the upper manifold.
http://www.rotaryresurrection.com/2ndgen/techmenu.html
509-998-9024
lvmckane
efi progression
posted April 08, 2011 11:54 AM
wow didnt know that existed thanks bunches!
sevenstock 14 or bust!
0.023376941680908 seconds processing time
