Index > Engine/Drivetrain > Thread: Truck won't start
Captainkrm
posted April 24, 2011 08:19 PM
Truck won't start
Not sure why, but truck won't start. Tried new battery, lights and brake lights work, but ignition switch does not seem to do anything. Swapped fuses too in the column wiring. Starter is getting power too. Any thoughts?
Klaus42
posted April 26, 2011 01:23 PM
Edited By: Klaus42 on 26 Apr 2011 13:25
The obvious? It's the ignition switch itself that's (partially) failed/failing internally.
Of course, that's no guarantee that's what it is... but you might try bypassing it and see what happens.
("De-ox-it"-type electronics contact cleaner is also your friend!)
Poor/corroded connections will add resistance to a circuit.. Also look for a bad ground/grounds... maybe go over/clean/tighten every ground you can find. Is the ground strap from your engine to chassis intact?
Then there's always broken/compromised wiring *within* the insulation...
captainkrm
posted April 26, 2011 03:10 PM
turned out to be a corroded wire at the distribution block, repaired and hence truck now runs once more! thanks!
0.017804861068726 seconds processing time
