Index > @ the Pickup Bed (General Topics) > Thread: aftermarket part numbers........
posted January 14, 2004 10:19 PM
Edited By: nwaco on 14 Jan 2004 23:08
Aftermarket Part Numbers........
Here is something you won't see on one of those "Bargain Forum's".
A little reference material for everyone. I collected these part numbers and thought others might like to see.
Part Description, Part Number, Year, Qty Per Vehicle
FRONT SUSPENSION
MOOG
Upper Control Arm Shaft Kit, K9154, 74 -77, 2
Lower Control Arm Bushing/Kit, K9178,74 -77,2
Upper Ball Joint, K9026, 74 -77,2
Lower Ball Joint, K9049, 74 -77,2
Sway Bar Link/Kit,K447, 74 -77,2
Sway Bar Frame Bushing/Kit, K9246, 74 -77, 1
Steering
MOOG
Idler Arm
IMPROVED DESIGN, K9096, 74 -77, 1
Idler Arm Repair Kit, K9088, 74 -77, 1
Inner Tie Rod End, ES2074R, 74 -77, 2
Adjusting Sleeve, ES2729S, 74 -77, 2
Outer Tie Rod End, ES2073L, 74 -77, 2
Stabilizer Cylinder, SSD63, 74 -77, 1
Stabilizer Kit, SSD32, 74 -77, 1
Brakes and Wheel Bearings
WAGNER
Front Anti Squeal Kit, SH048-5, 77, 1
RECOMMENDED REPLACEMENT IS ORGANIC
Front Disc Pads, 7009, 77, 1
Front Left Caliper With Pad,
QUICKSTOP, L107378, 74 -77, 1
Front Right Caliper With Pad
QUICKSTOP, L107379, 74 -77, 1
FITTED, SH048-5, 77, 1
Front Premium Non Asbestos Pads
THERMOQUIET, PD76, 77, 1
LEE MANUFACTURING
Front Caliper Kit, 16008, 74 -77, 2
WAGNER
Front Left Rebuilt Caliper, CR107378, 74-77, 1
Front Right Rebuilt Caliper, CR107379, 74-77, 1
QUICKSTOP, L107378, 74-77, 1
QUICKSTOP, L107379, 74-77, 1
LEE MANUFACTURING
Front Disc Hardware Kit, 15536, 74-77, 2
SUPERSEDED, 15536-2, 74-77, 2
Front Pin/Key Retainer, 15352, 74-77, 1
SUPERSEDED, 15352-2, 74-77, 1
GIBSON PRODUCTS
SUPERSEDED, 15536-1, 74-77, 2
WAGNER
Rear Rebuilt Brake Shoes
10 1/4" X 1 49/64", 395, 74-77, 1
Rear Premium Shoes
THERMOQUIET
10 1/4" X 1 49/64", PAB395, 74-77, 1
WAGNER
Rear Wheel/Cylinder-Left
13/16", F100750, 74-76, 1
Rear Wheel/Cylinder-Right
13/16", F100751, 74-76, 1
Rear Wheel Cylinder Kit
13/16", F100969, 74-76, 2
Rear Brake Hose
13/16", F100785, 74-76, 1
13/16", WC100750, 74-76, 1
13/16", WC100751, 74-76, 1
13/16", WK100969, 74-76, 2
Rear Brake Hose
13/16", BH100785, 74-76, 1
WAGNER
3/4" - upper, F100697, 77, 1
3/4" - upper, F100698, 77, 1
Rear Wheel Cylinder
3/4" - lower, F100696, 77, 2
3/4", F100967, 77, 2
3/4" - upper, WC100697, 77, 1
3/4" - upper, WC100698, 77, 1
Rear Wheel Cylinder
3/4" - lower, WC100696, 77, 2
3/4", WK100967, 77, 2
WAGNER
Remanufactured Master Cylinder
w/PWR BRAKES, R131616, 74-77, 1
Wheel bearings and seals
BOWER/BCA
Front Outer Bearing, 30204, 74-77, 2
Front Inner Bearing, 30206, 74-77, 2
Rear Inner Bearing, 30208, 74-77, 2
NATIONAL
Front Inner Seal, 1992, 74-77, 2
Rear Outer Seal, 1994, 74-77, 2
Rear Inner Seal, 473823, 74-77, 2
Clutch and Flywheel
BOWER/BCA
Release Bearing Assembly
225MM CLUTCH, FC1723C, 74-77, 1
Pilot Bearing, 152016, 74-77, 1
Gaskets & "Seals
NATIONAL
Rear Main Seal, 226840, 74-77, 1
Timing Cover Seal, 2025, 74-77, 1
Timing Cover Seal
REPAIR SLEEVE, 99169, 74-77, 1
Manual Transmission
BOWER/BCA
Front Transmission Bearing
4B, 4TA
4 SPD MAN TRANS, 306L, 74-77, 1
4R, 4 SPD MAN TRANS, 307L, 74-77, 1
5R, 5 SPD MAN TRANS, 307L, 74-77, 1
Countershaft Bearing
FRONT
5R, 5 SPD MAN TRANS, 5205KLE, 74-77, 1
Rear Transmission Bearing
5R, 5 SPD MAN TRANS, 305, 74-77, 1
Auto Transmission
NATIONAL
Automatic Transmission Front Pump Seal
JATCO 3N71, 2025, 74-77, 1
REPAIR SLEEVE JATCO
3N71, 99166, 74-77, 1
Automatic Transmission Rear Seal
JATCO 3N71
SUPERSEDED, 1216, 74-77, 1
JATCO 3N71, 1216N, 74-77, 1
Joints & Drive shafts
BOWER/BCA
Center Support Bearing, 205, 74-77, 1
PRECISION U-JOINT CORPORATION
Joint
ALL LOCATIONS, 397, 74-77, 1
Drive Axle Parts
BOWER/BCA
Front Pinion Bearing
REAR AXLE, 30306, 74-77, 1
Rear Pinion Bearing
REAR AXLE, 30307, 74-77, 1
NATIONAL
Pinion Seal
REAR AXLE
FRONT, 712011, 74-77, 1
Pinion Seal
REAR AXLE
FRONT REPAIR SLEEVE, 99157, 74-77, 1
Battery Parts
POWERPATH
OE INCLUDES BATTERY & BODY
GROUND STRAP IN A SINGLE CABLE
Battery/Switch Cable, 715534, 75-77, 1
Battery/Ground Cable
REQS FOLLOWING COMPONENT, 712234, 75-77, 1
Battery/Ground Cable, 712394, 75-77, 1
Ignition & Electrical Parts
CHAMPION WIRE & CABLE
O.E.M. INCLUDES BATTERY AND BODY GROUND STRAP IN A
SINGLE CABLE
Battery/Switch Cable, 64046, 74-77, 1
REQS FOLLOWING COMPONENT, 64010, 74-77, 1
Battery/Ground Cable, 64009, 74-77, 1
SUPERSEDED, 780136, 75-77, 1
Battery/Switch Cable, 781136, 75-77, 1
SUPERSEDED, 780119, 75-77, 1
Battery/Ground Cable, 781119, 75-77, 1
BOWER/BCA
Front Alternator Bearing
50, 63 AMP, 203FF, 74-77, 1
60, 65, 70 AMP, 302CC, 77, 1
Rear Alternator Bearing
50, 55, 60, 65 AMP, 201CC, 74-77, 1
Fuel
CARTER
Electric Fuel Pump
UNIVERSAL -
EXC w/FUEL INJ, P60504, 74-77, 1
Cooling
CARTER
New Water Pump, FP1730, 74-77, 1
Vision & Windshield
ANCO
New Washer Pump, 65-01, 72-77, 1
Aerovantage Blade
KWIK CONNECT, 91-14, 72-85, 2
Winter Blade
w/ADAPTER, 30-13, 72-85, 2
Wiper Blade
SPECIALTY BLADE, 25-14, 72-85, 2
Aerovantage Refill
METAL FRAME - FITS 91 SERIES, 19-14, 72-85, 2
Aerovantage Refill
- FITS 91 SERIES
PLASTIC FRAME, N14R, 72-85, 2
Anco Type Refill
METAL FRAME, 12-14, 72-85, 2
Aerovantage Blade
Winter Blade
Wiper Blade
Aerovantage Refill
METAL FRAME - FITS 91 SERIES, 19-14, 72-85, 1
Aerovantage Refill
- FITS 91 SERIES
PLASTIC FRAME, N14R , 72-85, 1
Anco Type Refill
METAL FRAME , 12-14, 72-85, 1
POWERPATH
Lifetime Pro Wires, 700187, 74-77, 1
5 Year 50,000 MILE WIRES, 60334, 74-77, 1
5 Year 50,000 MILE WIRES, 780034, 74-77, 1
Lifetime Wires, 60034, 74-77, 1
CHAMPION SPARK PLUG
SPARK PLUG GAP, '.040 74-77
POINT GAP, '.018, 76-78
POINT DWELL, 55-61, 76-78
IGNITION TIMING
TRAILING,
w/VACUUM HOSE CONNECTED, 20ATDC, 77-78
IGNITION TIMING - LEADING
w/VACUUM HOSE CONNECTED, 5ATDC, 77-78
FIRING ORDER, 1-2, 72-92
posted January 15, 2004 09:29 AM
Thanks!!!
Ken, this rocks!
Only thing I can think to mention: I'd NEVER recommend to anyone that they run anything other than the 'proper', rotary-specific, multiple sidewire, or more modern 'BUR' series NGK plugs... Call it personal preference, but my own experience is that there are considerable differences in response at certain RPM ranges even within the different versions of the rotary-specific plugs. Not to mention that single-sidewire plugs are a distinct disadvantage, given the directional nature of travel of the rotary's charge, and the incredible speeds it attains... Think about it: the final position the plug is in can affect ignition.
Plus, NGK's have long been the plug of choice for 2-stroke motorcycles... and our rotaries essentially ARE 2-strokes...
Of course, just about any plug will *sorta* work... some may even seem to work better--for a while--at certain RPM's...
And apparently, even Champion made a rotary-specific 'non-side-wire' style plug...
posted January 15, 2004 10:04 AM
yea, Klaus, me too on the NGK's , but.....
I threw everything I had collected in my "Federal-Mogul" file in there and actually when I saw it later, I was going to cut it out, but I got a message that I can't edit after an hour anymore?
Is this a new restriction? Probably just as well, but I can guess why lately......
posted January 18, 2004 10:08 PM
Some more from the aftermarket.....
These are some of the part numbers for Raybestos aftermarket parts for our trucks. I believe these to be correct.
Part Description, part number, Vehicle, year, qty per vehicle
Bleeder Screw,S22068,Rotary Pickup, 74-77, 2 - 4
Brake Drum-rear, 9108, Rotary Pickup, 74-77, 2
CALIPER ASSEMBLY - LOADED LEFT, RC3280, Rotary Pickup, 74-77, 1
CALIPER ASSEMBLY - LOADED RIGHT, RC3279, Rotary Pickup, 74-77, 1
CALIPER ASSEMBLY - UNLOADED LEFT, RWC45583, Rotary Pickup, 74-77, 1
CALIPER ASSEMBLY - UNLOADED RIGHT, RWC45582, Rotary Pickup, 74-77, 1
CLUTCH MASTER CYLINDER, CMA39258, Rotary Pickup, 74-77, 1
CLUTCH MASTER REPAIR KIT, CMK984, Rotary Pickup, 74-77, 1
CLUTCH SLAVE CYLINDER, SC37551, Rotary Pickup, 74-77, 1
CLUTCH SLAVE REPAIR KIT, CSK1232, Rotary Pickup, 74-77, 1
Front Pad Set, D76, Rotary Pickup, 74-77, 1
Front Pad Set, PGD76, Rotary Pickup, 74-77, 1
Front Pad Set, RPD76 Rotary Pickup, 74-77, 1
HARDWARE WHEEL KIT, H15536, Rotary Pickup, 74-77, 2
HOLD DOWN AXLE KIT, H14020, all models, 74-77, 1 - 2
HOSE - FRONT LEFT, BH38564, Rotary Pickup, 74-77, 2
HOSE - FRONT RIGHT BH38564, Rotary Pickup 74-77, 2
HOSE - REAR, BH38132, Rotary Pickup, 74-77, 1 - 3
MASTER CYLINDER ASSEMBLY W/O POWER, MC39254, Rotary Pickup, 74-77, 1
PIN/CLIP RETAINER, H15351, Rotary Pickup, 74-77, 4 - 8
RETURN SPRING, H10231, all models, 74-77, 1 - 2
SHOE/PAD SET - REAR, 395PG, Rotary Pickup, 74-77, 2
SHOE/PAD SET - REAR, 395RP, Rotary Pickup, 74-77, 2
Shoe/Pad set- REAR, 395, Rotary Pickup, 74-77, 2
WHEEL CYLINDER - LEFT REAR, WC37322, Rotary Pickup, 74-76, 2
WHEEL CYLINDER - RIGHT REAR, WC37322, Rotary Pickup, 74-76, 2
WHEEL CYLINDER REPAIR KIT - REAR, WK854, Rotary Pickup, 74-76, 4
Wheel Hardware Kit, Front, H15536, Rotary Pickup, 74-77, 2
WHEEL CYLINDER - LEFT REAR, lower, WC37472, Rotary Pickup, 77 2
WHEEL CYLINDER - LEFT REAR, upper, WC37463, Rotary Pickup, 77, 1
WHEEL CYLINDER - RIGHT REAR, lower, WC37472, Rotary Pickup, 77, 2
WHEEL CYLINDER - RIGHT REAR, upper, WC37464, Rotary Pickup, 77, 1
WHEEL CYLINDER REPAIR KIT - REAR, WK1477, Rotary Pickup, 77, 2
Front Rotor, 9260, Rotary Pickup. 74-77, 2
WIX numbers (74 - 77)
Air Filter, 42324, 1308cc ROTARY PICKUP
Fuel Filter, 33032, 1308cc ROTARY PICKUP
Oil Filter, 51356, 1308cc ROTARY PICKUP
I've got more to come when I get them reformatted.
posted January 19, 2004 09:57 AM
Thanks!!!
Just a thought: Might be easier to print out if you put the next batch in a new thread all it's own...
mazdarx605
posted June 20, 2004 05:13 AM
Hey guys quick question.I need new rear shoes and I got the apprpriate part number for them,but my question is do these shoes come with all the springs and such?Because i need those as well.Any help would be appreciated.
74 Green REPU
0.023462057113647 seconds processing time
