Index > @ the Pickup Bed (General Topics) > Thread: VIN location?
MWPAYNE1
posted May 07, 2013 05:33 PM
VIN location?
Is the VIN plate located at the usual spot on drivers side dash at bottom of windshield? Mine doesnt seem to be there, is there another way of finding it in case its missing?
MWPAYNE1
posted May 07, 2013 05:45 PM
Never mind, its on drivers side door plate.
dhood
posted May 07, 2013 06:44 PM
Hey Mr. Payne. I found one on the crossmember of a 75 after removing it. I no longer have that part to check. Recently went to look for the one on my 77 and couldn't find it. If it makes a difference.
dhood
posted May 07, 2013 06:46 PM
Not the plate itself, which was on the shelf above the firewall on the passenger side. The VIN number was stamped into the crossmember.
posted May 13, 2013 09:56 AM
I found my VIN also stamped on the frame rail. Drivers side, very front, top side. In the engine compartment. Never knew it was there except I cleaned and painted the frame and the numbers magically appeared once the grime was removed.
0.024785041809082 seconds processing time
