eldudo
posted January 21, 2013 07:21 AM |
Edited By: eldudo on 21 Jan 2013 07:22
Carb
Guys, I had my carb apart a while ago and was trying to do the solder trick to block the vacuum bleed off. Long story short the "pin" broke in half as I was soldering it. I've recently switched to the Weber 48 carb, but want to replace the pin in case I ever switch back to stock.
Let me know if anybody has found a place to get that little brass bastard.
