Index > Suspension > Thread: adjusting rear drum brakes - revisited
posted May 05, 2006 10:18 AM
So how tight do we adjust the rear drum brakes to?
Factory shop manual says to tighten them up so the drum does not move at all, then back off the star wheels 5 clicks.
Is that right? That sounds pretty darn tight. Dragging brakes...
How do you adjust your rear brakes?
posted May 05, 2006 10:37 AM
Just like you said...
...you do the adjustment as described, then go out and seat them by doing some hard braking... then, re-adjust as needed to achieve the desired effect. Repeat as nessecary; back off as nessecary to not drag...
0.012557983398438 seconds processing time
