Thread: Brake master cylinder?
posted June 10, 2004 01:04 PM |
Anybody know where would be a good place to find a new brake master cylinder and reservoir? I know one was just on ebay in the last few weeks but I didnt get to it in time. Mine was replaced with the master cylinder off an RX4. It fits but my REPUreservoir leaks on it, res needs to be replaced any way as it is getting pretty old and rough looking. I either need an rx4 reservoir or an entirely new REPU master cylinder and reservoir. Any suggestions? Any other vehicles that use the same master cylinder?
posted June 10, 2004 04:38 PM |
Brake master cylinder......
I called napa a few months ago. They said they could order one for $108.00 and some change. I ended up getting one from craig of ebay. Good luck!
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
posted June 10, 2004 06:17 PM |
I can't say the best place to find it, but....
I can help with what to look for....
BRAKE MASTER CYLINDER
A1 CARDONE 11-1781 [Master Cylinder] Reman
AC DELCO DURASTOP BRAKES 18M139 [Brake Master Cylinder] Rotary Engine;Cylinder Bore= 7/8
AIMCO M900334 [Brake Master Cylinder] Rotary Engine;Cylinder Bore= 7/8
AUTOPRIDE PRIVATE LABELS 11-1781 [Master Cylinder] Reman
NAPA/AMERICAN REMANUFACTURING ARI83-14500 [Master Cylinder] 7/8 ;
AMERICAN REMANUFACTURING INC. 83-14500 [Master Cylinder] 7/8 ;
AUTOSPECIALTY M-53500 [Master Cylinder] 7/8
AUTOLINE 20-3038 [Master Cylinder] Disc; w/Power
BRAKEWARE 10084 [Master Cylinder Assy.] Power; 7/8
CARQUEST E98232 [Brake Master Cylinder] Rotary Engine;Cylinder Bore= 7/8
NAPA/A1 CARDONE TS 11-1781 [Master Cylinder] Reman.
CENTRIC PARTS 130.45500 [Master Cylinder]
CROWN 11-1781 [Master Cylinder] Reman.; Disc
FENCO M51781 [Reman Master Cylinder] All
FRICTION MASTER 1781 [Master Cylinder] Reman.; Disc
THE HASTINGS Co. King N.C. MC 10-2501 (reman. Master Cylinder)
PERFECTION CLUTCH 11-1781 Disc
RAYBESTOS MC39254 [Brake Master Cylinder] Rotary Engine;Cylinder Bore= 7/8
TRU TORQUE M39254 [Master Cylinder Assy] Power Front Disc Brakes; 7/8 Dia Bore
NAPA/UNITED UP 39254 [Brake Master Cylinder] Rotary Engine;Cylinder Bore= 7/8
WAGNER F100758 [Brake Master Cylinder] New; 3/4 Bore; w/Vac. Boost; P/U List.
WAWD 1854434000 N/A
WAGNER CATEGORICAL NUMBERS MC100758 [Brake Master Cylinder] New; 3/4 Bore; w/Vac. Boost; P/U List.
WAGNER REMANUFACTURED R131616 [Master Cylinder] Reman.
BIG A F100758 [Master Cylinder] 3/4; w/Vacuum Boost; Pickup Listing
BRAKE MASTER CYLINDER KIT
NAPA/BECK ARNLEY BA 071-6530 [Brake M/Cyl Kit-Major] Major repair kit with piston.
BECK/ARNLEY 071-6530 [Brake M/Cyl Kit-Major] Major repair kit with piston.
CARQUEST M1219 [MASTER CYLINDER REPAIR KIT-DRUM]; 1600 Single Cylinder; Brake Master; <3/4> Inch Cylinder Bore
CARQUEST M7327 [MASTER CYLINDER REPAIR KIT-DRUM]; 1600 Tandem Cylinder Up to 3/74; Brake Master; <3/4> Inch Cylinder Bore
CARQUEST M7326 [MASTER CYLINDER REPAIR KIT-DRUM]; 1600 Tandem Cylinder After 4/74; Brake Master; <3/4> Inch Cylinder Bore
RAYBESTOS MK1249 [Master Cylinder Repair Kit-Drum] 1600 Tandem Cylinder Up to 3/74; Brake Master; <3/4> Inch Cylinder Bore
RAYBESTOS MK1727 [Master Cylinder Repair Kit-Drum] 1600 Single Cylinder; Brake Master; <3/4> Inch Cylinder Bore
RAYBESTOS MK848 [Master Cylinder Repair Kit-Drum] 1600 Tandem Cylinder After 4/74; Brake Master; <3/4> Inch Cylinder Bore
NAPA/UNITED UP 1249 [Master Cylinder Repair Kit-Drum] 1600 Tandem Cylinder Up to 3/74; Brake Master; <3/4> Inch Cylinder Bore
NAPA/UNITED UP 1727 [Master Cylinder Repair Kit-Drum] 1600 Single Cylinder; Brake Master; <3/4> Inch Cylinder Bore
WAGNER F100759 [Brake Master Cylinder Kit] 3/4; w/Vac. Boost; P/U List.
WAGNER CATEGORICAL NUMBERS MK100759 [Brake Master Cylinder Kit] 3/4; w/Vac. Boost; P/U List.
posted June 11, 2004 07:46 AM |
Thanks, with all that I should at least be able to find something!
posted June 13, 2004 11:12 AM |
The one you saw on Ebay
...was being auctioned by vintage imports, I believe? I seem to recall this seller semi-frequently listing these, so there may be more of them available. Also, I've been the winning bidder on some of his items in the past, and he's a good guy to do business with...
You might want to contact him, and see if he has another one for you.
posted July 15, 2004 10:36 AM |
Edited By: Tom93R1 on 15 Jul 2004 10:36
I was able to get a NOS master cylinder from a friend that is for a '75 Courier. It looks exactly the same as the REPU unit on the outside. Does anybody know for certain if these cross reference?
thanks
posted July 15, 2004 03:22 PM |
interchange
my references indicate that the Courier MC has a 1/8" smaller bore size than the REPU.
posted July 16, 2004 03:42 PM |
What a bummer :(
Oh well, guess the search continues.
thanks
Tom
repujeff
posted August 31, 2004 07:52 PM |
Master Cylinder
Tom, did you get a master cylinder replacement and if so what? Jeff
posted August 31, 2004 10:13 PM |
I have been such a slacker. I still havent found anything. I just continue to add brake fluid ever so often and complain about it every time. I have a Courier master cylinder and I could just pull the REPU master cylinder off and just see how close they match up. I have been putting that off until winter. When it is 110 out I just have no initiative to tear into things like that. I will definately updatae this thread when I have found a replacement.
posted March 21, 2006 11:06 PM |
WELL, I'M LOOKING FOR A NEW BRAKE MASTER CYLINDER TOO
And have ordered from kragen.com and carparts.com, both sites cancelled my order due to the manufacturer not having any in stock. At all.
Just tried NAPA, we'll see how it goes. After that i'll look at autozone or carquest.
posted March 28, 2006 09:07 AM |
NAPA one arrived
And looks identical to the one on my truck now. Even says 7/8 F R on it too. $124 + tax and shipping.
