Index > Suspension > Thread: Coil Springs
Cappella
posted May 27, 2004 08:37 PM
Coil Springs
Anyone happen to have the Spec’s on a stock set of springs? My truck is lowered and I want to put it back to the original ride height.
        Click here to send Cappella an ICQ message. Click here to add 5945426 to your ICQ list.
prcracer
posted May 31, 2004 08:04 PM
'74 Factory Front Coil Spring Spec's
According to the Mazda Factory Spec Manual for '74 REPU the spec's are as follows:
Spring constant: 9.13 kg/mm (511 lb/in)
Wire diameter: 16.5mm (0.65")
Coil diameter: 100.5mm (3.96")
Free Length: 298mm (11.73")
Fitting length: 218mm (8.58")
Fitting load: 694~766kg (1530~1689 lb)
Hope this helps, Jeff
Cappella
posted June 05, 2004 01:04 PM
Thanks for the specs, I found a shop that makes springs near where I live. I guess I will pay them a visit to see of they will be able to make a set of springs.
0.011055946350098 seconds processing time
