Index > Trucks or Parts WANTED > Thread: WTB: Engine Mounts
posted May 05, 2004 09:21 AM
WTB: Engine Mounts
Does anyone have an extra set of Engine Mounts for the REPU? I guess the T2 is too hard on the orig's :)
I found this thread talking about solid motor mounts.. maybe something I could do... but I'd like something in the mean time.
I'm The Admin, thats why!
posted May 05, 2004 10:42 AM
engine mounts
Looks to me like Mazda still sells them ... cheap.
2003 catalog says $23 for # 1668 39 040 D
I have some used one $15 each.
Bruce Toski
954 583-4191
posted May 05, 2004 06:31 PM
Engine Mounts
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2477271260&category=50454&sspagename=WDVW
Try here on e-bay, these might be what your looking for.
posted May 06, 2004 09:34 AM
Ooh!! Very cool! Solid Motor Mounts...
posted May 06, 2004 11:12 AM
I tried solid mounts in my REPU once. They were a stack of washers and some rubber pads. Too much noise and vibration. The front cover to front mounting plate bolts started wearing on the threads. I got a good used 1st gen RX-7 rubber mount to replace my bad one and swapped them back in. I seem to like stock mounts better, but maybe I should have tried the solid mounts without the rubber pads because they compressed over time and the tension loosened up.
My latest project seems to be doing what my REPU did back when it had a bad motor mount. Perhaps this is a good time to try solids again? I won't bid on the eBay ones. Get 'em! :) Besides, I think Scalliwag is making some right now.
posted May 06, 2004 12:21 PM
Perhaps as an option of last resort?:
...I do have a pair of original, old, used rx-4 engine mounts...
posted May 07, 2004 10:50 AM
Edited By: Jeff20B on 7 May 2004 10:54
They'd work fine.
Actually, how well they work depends on wear. I noticed the RX-3 mount with a spare RX-7 mount in my GLC feels as squishy as my REPU used to feel. I might try a torque brace this time simply because there are some strut towers to hook a cable to.
A cable perch could be welded to the upper passenger corner of the engine bay of our trucks. Then something could connect it to the two bellhousing bolts nearby. It would have to be a metal rod like the RB unit because the engine torques that direction under acceleration.
posted May 07, 2004 11:15 AM
Probably worth going with NOS...
...if they're still available... nothing like doing the job once, instead of over and over...
posted May 09, 2004 12:15 PM
does anyone make polyurethane motor mounts?
for repu? that would be a nice compromise between rubber and aluminum. normal and harsh vibration.
do 1st gen rx7 motor mounts work on repu?
posted May 09, 2004 01:59 PM
I think the one I used was from a 1st gen.
0.025015115737915 seconds processing time
