Index > Engine/Drivetrain > Thread: why not? motor mount D????
originalrecipekenny
posted February 15, 2013 08:32 PM
i have a sweet deal lined up on an 87 turbo engine and transmission. i have read that using an early 13b front housing will allow me to just bolt the engine in. has anyone made the mounting style from the 87 rx-7 work? if i do go with an earlier 13b style front housing what kind do i want to look for??? repu, 1st gen rx-7, cosmo???
posted February 16, 2013 11:45 PM
It's not the early front housing that lets you bolt it into a repu, it's the early front COVER. Also known as the timing cover...which has 4 studs on the front of it which attach to the stock REPU motor bracket then to stock REPU motor mounts.
87 motors had the motor studs on the sides of the motor.
You'll also need the oil pan from a 84-85 GSL-SE 13b motor. Or a stock REPU oil pan. And the oil pickup tube from any 79-85 rx7.
Getting the transmission to fit with the shifter in the stock hole is another story.
fliboyz6
great
posted February 17, 2013 03:52 PM
I actually have that exact setup in my truck.... Had it rebuilt by jesus and slapped it in with a stock t2 lower modified to accept a dcoe carb... Im super pleased with the choicebi will post a pic on the facebook page
originalrecipekenny
posted February 17, 2013 09:08 PM
I knew what part I ment and and now looking back I sound like a... Piston person....
I did hear about the pan. But not the dip stick. What's up with that? Clearance issues at the bottom of the pan?
My floor boards are completely toast so moving the shifted shouldn't be too big of a deal. How much are we talking about? Should only be six inches of so right?
What front cover do I want? I've heard of people using a lot of different ones but never any pros and cons.
spokanerxdude
Less cubes... More balls
posted February 18, 2013 04:53 AM
Edited By: spokanerxdude on 18 Feb 2013 04:54
84-85 GSL SE Front cover. Dip stick is the same.
509-998-9024
jm1fd
posted February 18, 2013 10:55 AM
So a REPU front cover isn't compatible with the later engines?
fliboyz6
great
posted February 18, 2013 01:06 PM
Stock front cover is compatible with all the newer engines but tje gsl-se is an upgrade with the 4port omp for those who dont have a stock cover
posted February 18, 2013 08:29 PM
You'll have a hard time finding a gsl se front cover, very rare. Most use 79-85 12a front cover since they made so many of them. Any 74-85 front cover will work. Single distributor.
originalrecipekenny
posted February 18, 2013 09:15 PM
Cool. I do have a ton of wrecking yards close by and gsl-se pop up from time to time.
originalrecipekenny
posted March 17, 2013 11:00 AM
i got the front cover and the oil pan for very cheap from the guy i bought my truck from.
0.024264097213745 seconds processing time
