Index > Engine/Drivetrain > Thread: Need a radiator...
Thread: Need a radiator... [' This thread is 2 pages long: (1) 2 ']
top1usa
posted September 22, 2011 08:35 PM
Need a radiator...
I search high and low for a radiator for my 74' but with no success! Can anyone provide any leads to an oem or aluminum radiator??
Shop is saying is beyond repair but if I insist of re coring it...it'll run me about 3 bills! Mind as well get a new one or aluminum!
Any help would be appreciated!
Tim
dryenko
posted September 23, 2011 05:05 AM
I have a good used radiator, plus other stuff
I have nice one sitting in my shop on a shelf, along with a nice front bumper and very good metal valence, 2 front fenders, hood with chrome strip, rear end center section, rear axles and brakes, rebuilt front calipers, new 9 bolt clutch cover and disc, 13B carbs, nice front grill [3 pcs] and a bunch of other new and good used REPU parts in boxes.
Located at Zip code 27017
Trouble is, no one in REPU land wants to pay what this stuff should sell for, given how rare it is getting.
Bob C
top1usa
posted September 23, 2011 06:50 AM
Detail pics?
Bob C
Bob,
Thanks for your reply! I totally understand what you're saying but at the same time...times are tuff for lot of people despite the rarity of these items. I had a budget for my 74' but all that went out of the window after the body shop got done with it! Anyhow, could you please send me some pics of the radatior? Does it need to be re-core or will I able to drop it in just the way it is?
Please send pics to: top1usa@gmail.com and put Repu items on subject!
Thanks so much in advance!
Tim
posted September 23, 2011 09:02 PM
http://cgi.ebay.com/ebaymotors/aluminum-radiator-MAZDA-RX2-RX3-RX4-RX5-RX7-S1-S2-69-83-/110640639486?pt=Motors_ATV_Parts_Accessories&hash=item19c2b22dfe
I'm using this radiator and it works great. Just have to drill the mounting holes.
posted September 23, 2011 09:39 PM
Thanks Jeff. I need a radiator too. Great price too.
posted September 23, 2011 09:49 PM
Edited By: sparky on 23 Sep 2011 21:49
Just bought it.
Hey Jeff, Are you using electric cooling fan? If so, where did you buy it?
posted September 25, 2011 08:59 AM
Cooling Fan
Yeah, I'm using a fan in front of the radiator, pushing air thru. Don't remember where I got it from, but its like a 14" fan.
Just get on Ebay and search, there are plenty of them out there.
Good luck, I'll try to get some newer pics of my engine bay up soon. Old ones are kinda dated.
posted September 25, 2011 09:05 AM
This was before I put the new radiator in.
http://mazdarepu.com/Gallery/index.php3?album=Charles+REPU+Restoration&photo=uploads/2007_0625_125731AA.jpg
top1usa
posted September 25, 2011 12:10 PM
Edited By: top1usa on 25 Sep 2011 12:10
Thanks a bunch jfaplanet! I do have another question for you tho...this aluminum radiator looks great and I will purchase one for sure. What about the oil cooler that attached to the bottom of the oem radiator? What did you do for that?
posted September 25, 2011 02:45 PM
It has the mounting bungs on it, but I had to fab some new mounts to attach it, the stock ones wouldn't quite work just right, and the rubber on mine was really dry rotted. I just made solid mounts.
top1usa
posted September 25, 2011 03:07 PM
Thanks again for that jfaplanet! Most likely will need to purchase an oil cooler recommended by Brad from one of his older post. Will see if mechanic can do his magic with that......
Much thanks! Great help....
Tim
PS...am actually going to purchase that radiator you'd recommended!
TimPA136
posted September 25, 2011 07:55 PM
Tim
Timtop 1,
I have good condition extras of the 4 oil cooler rubber mounts if you would like you're welcome to them.
TimPA136
posted September 25, 2011 09:34 PM
I had an old rx7 radiator and the oil cooler mounts were beyond repair.
Ended up fabricating brackets and mounting oil cooler to frame rails in front of motor mount.
top1usa
posted September 25, 2011 10:29 PM
Edited By: top1usa on 25 Sep 2011 22:30
Tim
Timtop 1,
TimPA136
TimPA136...much thanks for your help! I would love to get them off your hand...please shoot me an email(top1usa@gmail.com) so I can pay you for those items. Where are you located??
top1usa
posted September 25, 2011 10:31 PM
Edited By: top1usa on 25 Sep 2011 22:33
I shall keep that in mind.....guess that would be the last resort!
Thanks a lot sparky!
Tim
PS....did you have any luck looking for that electric fan for the radiator?
posted September 27, 2011 11:57 AM
Edited By: Brad on 27 Sep 2011 12:02
That is a damn nice radiator. 4 pass, 2" thick, 3 row. My stock radiator was recored for $180. Brass 3 row core.
I use an electric fan called Syclone. It's not loud but I did have to fab a fan mount which was a lot of work. Buy the temperature probe & switch separately.
http://www.summitracing.com/parts/FLX-398/
Be sure to flush that radiator first before installing. New radiators can have aluminum weld slag rolling around in there which will eat the water pump or plug coolant passages in the block.
Klaus45
On two wheels
posted September 27, 2011 04:53 PM
Hey guys!
Been a while...
Just in case any of you did not yet know, this was Orville's yellow truck. Very cool to see it getting restored, IMHO.
Tim -- What they said! Be sure to have your oil cooler thoroughly cleaned out as well.
Cheers, Klaus
top1usa
posted September 27, 2011 06:28 PM
Edited By: top1usa on 27 Sep 2011 18:36
Thanks guys...
Brad, thanks...I will be sure to do that first before install! So glad you mentioned it because I was going to mount that sucker when it gets to my door! Thanks again!
Klaus45...I will be purchasing Brad's recommendation regarding the oil cooler! It will be new...do I still need to flush it out before install? Thanks a bunch!
74' Mazda Repu-Flare
yellow
85' Toyota ae86-Red-SOLD
88' Toyota ae92-Gray
14' Toyota Prius
posted September 28, 2011 02:13 PM
Always flush a new oil cooler. Poured a quart of cheap oil thru mine. Safe or sorry?
top1usa
posted September 28, 2011 04:49 PM
Rogered that Brad! Thank you kindly...
yellow
14' Toyota Prius
0.046516895294189 seconds processing time
