Index > Engine/Drivetrain > Thread: morosso oil oan
micah
posted July 30, 2011 08:27 PM
morosso oil oan
will this fit on a repu? hi guys yes im still alive ,,, truck is up and running... rebuilt by sons and I
mattraver
posted July 31, 2011 12:24 AM
as long as its the same shape as the gsl-se rx7 pan ,atkins rotary in washington has 6qt pans for repus for a little over 100.00 if you dont have the 400.00 moroso pan yet
posted August 01, 2011 01:54 PM
Yes it fits get the one that looks like this. It has a flapper trap door to keep oil in the big front sump under acceleration. And a Turbo oil return line port on passenger side. Aluminum rejects heat much better than stock steel pans and shines up nicely. Includes a stud and nut kit that is excellent!!!!! Use blue loctite to keep studs in the engine block.
posted August 03, 2011 11:34 AM
What happened Andy? You rebuilt the engine again?
micah
posted August 25, 2011 01:17 PM
Edited By: micah on 25 Aug 2011 13:19
Yes, engine is done nicely,,,new 4th stage clutch too, The truck was already was already running,,,,Son and I rebuilt it ,learned so much, I used Pineapple water seals,,,tested water system with rob's tester before this time,,,pinched a seal before,,,,,All work done in my garage,,,,got tired of giving peeps money to do work That I can do........Oil pan comes in tommorow. Gilmer drive soon and big intercooler,,,,I want on e like you see the ute's have,,,horizontal,,,,long
micah
posted August 25, 2011 01:19 PM
Yes, engine is done nicely,,,new 4th stage clutch too, The truck was already was already running,,,,Son and I rebuilt ,learned so much, I used Pineapple water seals,,,tested water system with rob's tester before this time,,,pinched a seal before,,,,,All work done in my garage,,,,got tired of giving peeps money to do work That I can do........Oil pan comes in tommorow.
posted August 25, 2011 07:09 PM
Glad u rebuilt the motor Andy, it is a learning experience that's for sure. But very rewarding. I just buzzed the one I built up to 8000rpms yesterday.....pulled hard.
It's a great oil pan I'm sure you'll like it. I coated mine with AlumiGlow as it will get dirty and oxidize.
http://www.poliglow-int.com/alumaglow.phtml
TimPA136
posted October 16, 2011 08:10 PM
oil pan
Micah,
Did you get the pan to fit?
All set for SEVENSTOCK?
0.027740001678467 seconds processing time
