Index > Engine/Drivetrain > Thread: Slave Cylinder Part Number correct?
77repu23
posted May 29, 2011 02:14 PM
Hi Guys I dug through the forum for a while and it seems the consensus with the slave cylinders you can get aftermarket are for the most part the fine thread 1st gen rx-7 ones.
I did however find this part number in the forum: SC37551
Rock auto says they have 1 in stock.
Is it the course thread or the fine thread?
Many thanks.
-Josh
Klaus45
On two wheels
posted May 29, 2011 10:07 PM
Best bet...
...might be for you to go take a look at it, and let us know.
77repu23
posted May 30, 2011 01:24 PM
RockAuto was the place that has one of those part numbers in stock so unfortunately I can't go look at it.
However, another possibility that came to mind was using the rebuild kit meant for a 1st gen rx7...
Do you guys know if that would work without a ton of modification?
Thanks again.
posted May 31, 2011 01:11 PM
New slaves and rebuild kits are still available.
Have a look here.
http://www.mazdatrix.com/f-hydral.htm
77repu23
posted May 31, 2011 01:13 PM
Thanks RepuMax! I already ordered the rebuild kit from Atkins. I'll let you guys know how it works out.
-Josh
MAZDAMARK
posted June 01, 2011 01:10 PM
Speaking of rebuilds, has anyone done one of these before? Do the rebuilt slaves last as long? I thought I remember hearing for longevity it is necessary to run a special hone through the slave bore to smooth out the wear ridge before using the rebuild kit... Is this true?
94 RX7
89 RX7 GTUs
85 GSLSE
88 323 GTX
1975 REPU
posted June 03, 2011 05:07 PM
If the bore is hosed a rebuild kit won't help much. You're right.
Autozone sells a clutch slave special order pick up (and return) at store or ship.
http://www.autozone.com/autozone/parts/1974-Mazda-Pickup/Clutch-Slave-Cylinder/_/N-iov5dZ6o2ja
$17.99
They also sell the clutch master. When one dies the other will soon.
0.022819995880127 seconds processing time
