Thread: 5 speed adapter plate
tankkira
posted July 05, 2010 04:35 PM |
Does any one have a schematic or drawing of a adapter plate for 5 speed swap? or point me in the direction of a post that does. thanks
posted July 05, 2010 07:09 PM |
adapter??
All Mazda Rotary Engines use the same transmission bolt pattern. At least up to 91. So if you want to swap in a 5 speed the only consideration is where the shifter will be. Turbo Trannys use a different flywheel and starter, but they too will fit.
tankkira
posted July 05, 2010 07:55 PM |
adapter for tranny cross member. 5 speed sits a little further back! shifter location is the same, I read on here 1/4 inch steel plate is sufficient enough. Just wanted to know if someone sketched one that fit. To eliminate trial and error method.
EricRyan
posted July 05, 2010 08:25 PM |
quote: adapter for tranny cross member. 5 speed sits a little further back! shifter location is the same, I read on here 1/4 inch steel plate is sufficient enough. Just wanted to know if someone sketched one that fit. To eliminate trial and error method.
Cardboard, sharpie and a welder. Get to it!
fliboyz6
great
posted July 09, 2010 10:50 AM |
im currently rockin the 5 speed out of a first gen and it fits on the stock cross member withe the stock mount and the only thing i had to do was notch out the floor becausae the shifter sits back further
tankkira
posted July 18, 2010 04:24 PM |
thanks for everyones help. my truck had two sets of holes for crossmember. Perfect fit with back two holes. Just waiting for exhaust gaskets to come. thanks.
