Index > Engine/Drivetrain > Thread: tranny removal?
tankkira
posted July 02, 2010 08:05 PM
tranny removal?
Any tips on tranny removal! Is there a step by step on here some where? I have a stock 4 speed in now, and I just picked up a cosmo 5 speed for my 77 repu :) Have done trannys on datsuns but never my repu. Any info greatly appreciated. Thanks
EricRyan
posted July 03, 2010 08:18 AM
If you've removed tranny's in other vehicles I don't see you having any problem getting the REPU's out.
posted July 03, 2010 10:51 AM
Nothing different with removing a rotary's tranny.
For the REPU specifically I unbolt the back of the driveshaft first (where it meets pinion flange), then the center bearing. Tap the driveshaft forward with a deadblow hammer. It can move in about 1" total. Then just pull it out.
A little grease or anti-seize on the pinion flange where it meets the driveshaft makes it immensely easier to unstick it next time.
Each tranny bolt is a different length so mark them on removal.
A spray paint can plastic cap fits nicely over the rear end of the tranny. Tape it on for storage.
I had a 77 5 speed and it had the best gearing for autocrossing. Stick it in 2nd and leave it there.
TimPA136
posted July 03, 2010 08:55 PM
Edited By: TimPA136 on 3 Jul 2010 21:40
Hmmm, I thought all 77s had 5 speeds.
Just under the shifter is a plastic cup/seat that don't last forever and blocks 5th gear, might be something to check unless you know it is a 4 speed.
Tim
tankkira
posted July 04, 2010 08:57 PM
Thanks Brad for your input! Tranny is out! Wasnt to bad, now just have to order up a few parts before putting back in. Will be nice not to only have 2nd and 4th, and know bonus 5th. Gonna be so nice!
tankkira
posted July 18, 2010 04:21 PM
thanks for everyones help. tranny in just waiting for some exhaust manifold gaskets to come. Wasnt to bad at all.
0.019531011581421 seconds processing time
