Index > Engine/Drivetrain > Thread: Stock Fuel Pump
mazdaorbust
posted May 03, 2009 04:03 PM
Stock Fuel Pump
Can anyone tell me what the spec's are on the factory fuel pump? How many
repu510
posted May 03, 2009 04:19 PM
Edited By: repu510 on 3 May 2009 16:19
Use a Carter. I'm using a P60504 as an OEM stock replacement and its been great on a stock ported engine w/ stock Hitachi carb.
Almost everyone in the rotary world will tell you to stay away from the Facet boxes... they can't deliver enough fuel volume for a rotary engine at high rpms and they fail quite often.
For an even better fuel pump, use the Carter P4070. Its good for stock up to street ported engines. Make sure to use a good fuel pressure regulator too!
posted May 03, 2009 06:31 PM
I use the Carter 4070
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRT%2DP4070&N=700+400415+4294836965+4294891681+4294782816+115&autoview=sku
Works with any carb. Put a clear plastic fuel filter before the pump, and another one right before the carb. Aides in troubleshooting if you're flowing fuel. The holley low pressure regulator is fine.
0.02220606803894 seconds processing time
