Index > Engine/Drivetrain > Thread: Oil sender
Thread: Oil sender
mwpayne1
posted February 23, 2007 01:19 PM
Oil sender
The previous owner had used a piece of piping screwed into
a 'tee', aftermarket oil pressure gauge attached to that.
That pipe snapped while running the engine in my driveway today. Cool oil geyser, put in a bolt for now.
What do you suggest as a place to check oil pressure? I don't think what I have is exactly 'stock'. Are the threads the same in that spot as an 85 engine, with the electrical presure sensor?
posted February 23, 2007 04:08 PM
Check Racing Beat:
See if they still offer their Oil Pressure and Oil Temperature Adapter -- It's a simple solution, however, it is not usable on '83 to '85 rx-7 oil-to-water coolers...
Mounts directly below the oil filter, and includes all O-rings.
Part# 11801 "'79 and earlier"
Part# 11802 "'80 and later"
(Do NOT include Gauges, senders, or adapter nuts.)
Racing Beat: (714) 779-8677
posted February 23, 2007 05:04 PM
I've installed oil pressure guages on previous rotary cars. Best way is to remove banjo bolt fitting for oil cooling line connection at rear of engine. Drill and tap bolt for 1/8" npt fitting. Install 90 deg. compression elbow into bolt and connect poly or copper tubing to after market guage. Good luck.
0.015521049499512 seconds processing time
