Index > Non REPU Rotary Trucks > Thread: Rotary in a 91 B22 some direction...
Thread: Rotary in a 91 B22 some direction... [' This thread is 2 pages long: (1) 2 ']
91B22Can
posted September 29, 2002 09:36 PM
Hey everyone, cool forum. I have a 91 b2200 standard cab, standad box, I have already put the 8v to the limits, and would like to go for a rotary, to be different, and I like roatries. I was wondering if anyone knew of a company that made engine mount adapters for this application or whether I have to custom make something? I couldnt seem to find anything so I thought this might be a good place to ask for some answers. I would just like to do a simple 13 B installation with a carb conversion so I wouldnt have to deal with engine harness and computer issues, I know not the most powerfull setup but something more than what I have. Any help would be greatly appreciated Thanks.
posted September 30, 2002 09:46 AM
Give me a while to upload some rotary B2000 pics to my geocities site.
posted September 30, 2002 09:54 AM
Ok, here you go.
http://www.geocities.com/cd23c/cars.html#b2000
By the way, it's an '86.
posted September 30, 2002 10:32 AM
Engine Mounting
My guess would be that you'd have to fab 2 engine mount extenders. This is not hard, you just need a good chunk of steel, and use the stock mounts for the RX-7. My guess is you'll use the 6port with the engine mounts in the center of the engine. I if this is the case, put the stock RX-7 mounts on the mounting location, then measure carefully the relationship between the tranny bell housing and where the mounts are. Use the steel as an "extender" to get the geometry in place. Drill your holes through the 'extender' and bolt it all up.
Also, don't forget to get a bigger fuel pump, I don't think the stock B-series truck pumps could pull that much fuel.
*rotarynews.com
*FD3s.net
*mazdarepu.com
-- Tom Matano
xgap
posted October 02, 2002 08:51 PM
Jeff!
Like your conversions!
I want to put a rotary(carb) in a 90 5.0 mustang. Also use the 5.0 T5 trans if possible. I assume, find a complete engine with carb and then rebuild if needed. Your ideas please. Thanks.
posted October 02, 2002 08:56 PM
Rotary Mustang !
That's Awesome! I've seen 5-point-slows put into RX-7's before (what a horrible thing to do) but not the reverse!
Junk yards are a great place to find engines, for $50 sometimes. The toughest thing would be making an adapter place for the tranny.
Kennedy Engineering maybe able to help with an adapter http://www.kennedyeng.com/
91B22Can
posted October 06, 2002 08:40 AM
Mounts
Hey Jeff 20B ( cooool truck ) How did you make the mounts for your truck, and how hard was it to get it running with the carbed intake ?? Like I said I'm somewhat new to rotary, I'm a big mazda fan so I know some but, not about the different versions that came in the RX's tho. What year should I be looking for one out of? Anything particular? thanks
posted October 06, 2002 09:28 AM
More Info Please
Jeff, do you have any more info on the Rotary to B2000 conversion. I just bought a 86 B2000 with a hole in the side of the block. I can buy a complete runnning 86 or newer RX-7 cheaper than I can buy a complete 4 cyl. I did a conversion on my 84 B2000 but that was way too much work. Are the newer ones easier. Mounts are not a problem, my questions are transmission, driveshaft, exhaust, etc. I've seen where its been done several times but there doesn't seem to be a lot of documentation on it. Any help is appreciated.
posted October 06, 2002 11:06 AM
Whoa, too many questions! :) It's not my truck and I didn't do the conversion. All I know is it's an '86 which has a wider frame and make rotary installs easier. I think it uses the '74-'85 front cover motor mounts but I could be mistaken. If you've seen the pics, you'll notice how far back the engine is in the bay (a dollar bill is 156mm long). The intake and exhaust stuff is from Racing Beat. The tranny is part RX-7, part B2000. That's all I know about it.
COsborne
posted October 12, 2002 11:08 PM
I found this site looking for information on how other people have fabricated engine mounts. Ive swapped a 2.2L Turbo engine into my 2nd gen rx7 race car. I know a fair amount about the swap for the b2000/b2200 as Ive used a lot of parts from the b2000. Feel free to ask me whatever you want.
1987 Mazda RX7 Turbo II
Mods: K&N Intake-3" Open Exhaust-Electric Fan-Air Pump Removed-ACV Removed-BAC Removed-Solenoids removed-Spider Removed-Fast Idle Cam Removed-TB Coolant line removed-Secondary Butterflies removed-A/C Removed-Twin Scroll Removed-Intake Manifold Ported-Turbo Compressor Housing Ported-3" Custom Cold air TID-Fuel Cut Defencer-A'PEXi Twin Chamber Blow Off Valve-HKS Type 1 Turbo Timer-HKS Manual Boost Controller
1988 Mazda MX6 GT
Mods: Engine Removed to reduce weight
1989 Mazda RX7 GTU
Mods: 2.2L Turbo
WHIZ
posted October 30, 2002 08:11 PM
Seems to be since I became a member of thiis site not more then a few days ago I've ran into several people looking to do the swap into the 86-93 B series MADAWGS. If anyone needs info or has info that can help please contact me. I think Im going to create a site geared towards this swap. Im having the same probs as alot of you. I have an 86 B series and an 87 TII as the donor. Now I just need to get the knowledge someone else has to do this swap.
DOES ANYONE KNOW WHO OWNS THIS TRUCK IN THESE PICS???
please e-mail me whiz72@comcast.net
WHIZ
posted October 30, 2002 08:18 PM
Sorry to keep posting but heres a link to my thread asking a very similar question earlier in the week.
http://mazdarepu.com/board/viewthread.php3?FID=1&TID=282
whiz
posted October 31, 2002 02:14 AM
You know I just saw a vid clip from 7-Stock of a B-Series conversion that had "Atkins Rotary" plastered on the windshield. It was a supercharged, carburated setup but still. It may or may not belong to someone who works there, or perhaps Atkins themselves.
It might be worth someone's time to drop an email over to Atkins to see if they know who it belongs to. I've hear they're friendly ppl, so it its theirs perhaps they'll be happy to talk to you a bit. If they do help just buy something from them to return the favour maybe. I dunno. Worth a shot.
posted October 31, 2002 09:36 AM
It's owned by a guy over in Post Falls, Idaho. He's got a rotary shop. I don't remember the name or the URL for his website though.
Uncle-Jim
posted October 31, 2002 01:15 PM
I think you guys are talking about Skip Gorman and his group. They opened a new shop in Post Falls, Id. Its called "Revolution Rotary". I'm about 75 miles from there, and I'd be happy to ask about their REPU.
The website appears to be;
<revolutionrotary.com>.
I haven't looked at it yet, but will soon.
Uncle Jim
whiz
posted October 31, 2002 02:11 PM
Edited By: whiz on 31 Oct 2002 14:12
I checked out the website earlier today when someone else told me where they were located. I have sent them an e-mail and even saw pics of a diff. REPU flat bed on thier site. Im hoping that between ATKINS,RACING BEAT, and These guys I can get some solid suggestions on this swap. Thanks for all the replys and all the help. Keep it coming.....
WHIZ
WHIZ
posted October 31, 2002 08:32 PM
Just got an e-mail back from revolutionrotary in Idaho. They dont do the swaps a street rod shop down the road from them does the swaps they just get them running. He also said they typically charge between 7-8 grand to do them. So in a sense I've hit a dead end there, I replied and asked if he could get me in touch with the street rod shop that does them ( I'll keep my fingers crossed ).
WHIZ
COsborne
posted October 31, 2002 09:57 PM
Well how much are you expecting to spend? $7000 is way too high but keep in mind its not free unless you do it yourself and even then if youre not experienced with that sort of swap then youre going to run into countless uncertainties and hangups. Trust me. I'm the first person to put an F series engine in an RX7 (Im basically doing it for the hell of it). I figure it will be fast and still handle well since my mx6gt ran 13s with minimal mods. Reply to the email I sent you with the links to my race car and if you want since youre so close we can possibly do the swap for you.
1988 Mazda MX6 GT
1989 Mazda RX7 GTU
Mods: 2.2L Turbo
WHIZ
posted November 05, 2002 03:31 PM
Has anyone heard anything new about this swap since last week?
marty-mcfly
Umm.. just started
posted December 09, 2003 01:10 PM
B2200 ---> RX7 twin turbo swap
Hey everyone.. i know this topic has been here quite a few times.. wasn't able to find any recent info after 2003 .. I'm just looking into swapping my exsisting 1990 B2200 engine with an Rx7 twin turbo.. Has there been any success stories on here with doing that?.. And are all Rx7 engine rotary cause i could've swore they stopped doing rotary around 1990.. I'd prefer to not go rotary.. i can't find one mechanic in this small town that does rotary.. and i don't kn ow enough about them yet to mess around with them.. any info or webpages would help me out a lot.. thanks guys.. love the forum..
0.037564039230347 seconds processing time
