Index > @ the Pickup Bed (General Topics) > Thread: steering box R&R?
posted July 03, 2007 11:09 AM
steering box R&R?
Anyone have a step by step for how to remove the steering box in our trucks?
posted July 05, 2007 08:43 AM
Did the box get removed Jeff?
Anyone have replacement parts for the steering box? After searching online everywhere, and searching Mazda's parts inventory the only new part I found was a gasket. Couldn't find any other Mazda parts supersessions either.
Anyone know if courier uses the exact same box?
posted July 05, 2007 10:00 AM
It's not removed yet.
Anyone?
posted July 05, 2007 10:06 AM
Edited By: Brad on 5 Jul 2007 10:09
From the MAZDA factory shop manual:
1. Put truck up on jackstands
2. Loosen the bolt securing the worm shaft to the steering joint.
3. Remove cotter pin and castellated nut attaching the center link to pitman arm.
4. Disconnect center link from pitman arm using a ball joint puller
5. Remove the screws attaching the insulator to the pitman arm and remove the insulator.
6. Remove the bolts and nuts retaining the steering gear housing to the body. At this point, check for the possible presence of aligning shim between gear housing and body.
7. Remove the steering gear from the vehicle.
8. Have an Asahi beer ;)
posted July 09, 2007 10:30 AM
Thanks for posting that. I still have some questions. Does it mention anything about removing the brake master cylinder for easier access? Is it necessary?
Also is there another way to disconnect the centerlink? I don't have a balljoint puller.
I don't think our trucks have an insulator on the driver's side. I know there is one on the passenger side. Is that what they mean? Is that the pitman arm? If so, why does it need to come off? It's all the way over there.
posted July 09, 2007 11:24 AM
brake master not mentioned at all and i doubt it's necessary since the steering box is on the outward side of the frame rails and down low.
it's a tapered press fit, gonna need a puller. i bit the bullet years ago and bought a sweet one from sears that's never failed. they can be used on so many other things & are great to have. any place rent them?
i couldn't find any insulator on the drivers side schematics. no pictures of it, dunno what it really is. i'd say just pull the box and keep an eye out for it.
posted July 16, 2007 03:22 PM
Edited By: Brad on 16 Jul 2007 15:27
well, since most REPU steering boxes are well worn
And mine is also all out of adjustment, I did some more research on it.
Called Lee Manufacturing in SoCal, they said they can rebuild the box and they should be able to get worm gear and sector shaft if needed too for additional cost. They have a great parts source they said. He even knew the Courier and B1600 use the same box. They just need to take it apart and see what's in there.
So Jeff, if your steering box is out this might be the way to go. He said just ship it to them and they'll rebuild it and call you to ask how to pay. ;) They'd even see if another ratio is available once it's apart!!!
http://www.leepowersteering.com/
Standard rebuild seals included, w/o any hard parts is $220 and they magnaflux everything. Equivalent to blueprinting.
posted August 07, 2007 01:43 PM
Hi Jeff,
How did the R&R go? Did the box get rebuilt?
0.030109167098999 seconds processing time
