Index > @ the Pickup Bed (General Topics) > Thread: SoCal REPU Run in August?
posted July 05, 2007 08:40 AM
Any REPU owners want to meet up at Steelhead Brewing Company in Irvine, CA this August? It's by UCI.
http://www.steelheadbrewery.com/irvine.htm
I'm open any saturday in August, what day works for you guys?
posted July 05, 2007 12:42 PM
Sounds good to me if my truck is road worthy. I just picked up a used bed. Haven't installed yet.
posted July 05, 2007 07:37 PM
Sounds good Brad. I went the steelhead in San Francisco years ago. I think I liked it. Can't quite remember.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
posted July 13, 2007 05:15 PM
Anyone else?
Interested?
posted August 01, 2007 09:29 PM
How about.....
Saturday August 25th????
posted August 02, 2007 09:49 AM
Can't make that date. I'm on call at work that weekend. Still working on the bed. Hope to have the truck on the road in a couple weeks. Hey Brad, After installing the Torsen I'm noticing alot of spring wind up on the rear axle. Do you have any ideas regarding traction bars for the REPU's? I'll most likely modify factory leaf spring clamps to minimize play from 2nd leaf removal.
posted August 02, 2007 10:09 AM
That day doesn't work for me either. Maybe we can all get together for dinner at Steelhead the day of sevenstock? Might be able to get more people to go as well.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1996 Aprilia RS 250
2004 Mazda RX8
2006 Yamaha Banshee
posted August 02, 2007 05:06 PM
Hi Sparky,
DID NOT notice that on my repu. Are you sure it's not just the rear tires trying to break loose due to putting more power to the ground now?
I bought from Pep Boys two dusty packages of leaf spring clamps. Showed them to ya at Stone. Very simple and effective way to clamp the leaves together in front of axel only. They do like to come loose, and creeeeak. I endedup using lots of blue loctite and that helped. Also use fat fender washers under the nylox. Mounted plate side down to keep it away from the gastank.
Now, traction bars. Yeah they're doable and help with straight line acceleration but mess up handling. Drag launch usage is their best fit. When I talked to Chris Greene he said he tried them at an auto-x once and promptly removed them. Same with cal-tracs.
The real deal leaf setup is composite mono-leaf springs. Weigh 60% less than steel, much thicker and eliminate axel wrap up. Also greatly reduce lateral movement. And track better over bumps, especially under braking when the rear of truck gets light. And you can have them made already lowered so you don't need heavy blocks and heavy longer u-bolts. And can specify spring rate.
http://flex-a-form.com/
Yeah I hear ya Max on SSX timeline, I was just hoping to do something sooner.
posted August 02, 2007 06:23 PM
Hey Brad, You and your gal are welcome to come down anytime. I'm about 2 miles from stone. Or we can hang out in the garage and BS about rotaries. I have a 1/4 barrel of Bastard flowing in the kegerator (which is in the garage) now!
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1996 Aprilia RS 250
2004 Mazda RX8
2006 Yamaha Banshee
posted August 02, 2007 06:35 PM
I have a whole lotta axle pivot. Also, after the leaf removal I immediatley noticed wheel hop when accelerating from stop. Even more after the Torsen upgrade. I was working on the frame with the bed off while sitting on the tire and was able to rock back and forth while observing axle. Driveshaft was not turning and axle looked really bad. For starters I'll drill and tap factory spring clamps and install jacking bolts with locknuts to take up play. If that doesn't work I'll opt for the clamps.
Thanks.
Scotty.
posted August 03, 2007 02:45 PM
Hey Scott, This thread is about BEER! hahahaha!
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1996 Aprilia RS 250
2004 Mazda RX8
2006 Yamaha Banshee
posted August 06, 2007 08:16 PM
Sparky,
Were the mains slapping against the rest of the leaf pack when rocking the tires back and forth? And pinion angle changing during?
I've seen that a lot on old and even modern mini-pickups.
And yeah, beer talk is good talk. How far u from Stone brewing? Might make a trip down there. Pony keg of Bastard is Good Times.
Anyone wanna go to Willow Springs Raceway this Sunday? N.A.S.A. is out there all weekend. My alam-motter.
posted August 07, 2007 06:28 AM
Regarding BEER. If you went to Max's I could make it. And pinion angle changes alot. I just installed jacking bolts on factory clamps and noticed improvement. Heven't driven the truck yet. Not sure on making to the speedway on Sunday.
posted August 07, 2007 06:35 AM
One of these days...
...I'm gonna come visit you guys... and drink yer Beer! Bwahahahahaha!
0.033594131469727 seconds processing time
