Index > Body Exterior > Thread: How to fix SLOW blinkers
rxkevin
posted April 03, 2005 06:54 PM
I was just wondering if anybody knows the trick to speeding up the blinkers... my blinks are about 5 seconds apart,
Thanks for any help
1984 RX-7 with 1993 13b rew drive train, t-66, power fc.
1974 REPU dellorto, racing beat header, 3 spd auto
posted April 04, 2005 09:15 AM
Blinkers work with/against resistance in the circuits. A burnt out bulb can stop some flashers.
Check for a bad bulb, corrosion at the sockets, and etc. on these old trucks. Otherwise, just change out the flasher unit, as they can go bad, and don't cost much. Avoid "heavy duty" as that usually means for towing trailers (extra bulbs in circuit). That would flash at the wrong rate as well.
formerly
rx2/3/4/cosmo,repu,94 rx7,
rxkevin
posted April 04, 2005 07:33 PM
cool, thanks
rxkevin
posted April 04, 2005 09:45 PM
Just to make sure... there are two diffrent relays for the blinkers... one being the gold box just to the left of the sterring collum, and the relay and circutry in the black box with the other relays in it located on the left kick panel. If this is so, the circutry needing to be replaced is the push in cartrige in the black box.... which is probably unavalible. (at least at "auto zone" type shops)
Thanks for any help on conferming the location of the relay..
Duncan
Historian
posted May 27, 2005 10:49 PM
You could also...
...switch to LED bulbs, which will cure the "slow" blinkers by default since they don't create as much electrical resistance. I've got a set of them in my 626 - they're brighter and they look really unique, at least under clear housings.
Join me at www.MazdaWorld.org - teach us about the classics!
Chuyler1
posted April 22, 2012 05:29 PM
Just to add to this thread, I had an issue with my "blinkers" and ended up cleaning all the relays and replacing the flasher module with one that is LED-safe. I don't have LED lights but it resolved the issues with the bulb load/resistance that I was having. Read the blog post below for details.
http://www.huyler.net/repu/?p=51
0.022310972213745 seconds processing time
