Index > Suspension > Thread: Grinding front brakes
posted March 03, 2004 10:40 PM
My passenger disk started grinding bad today. It looks like it was caused by metal to metal contact at the outside edge about 1/2" wide. Is it time for new pads? Or did one of the pad holders pop out? That has happened to me before, but on the backside inner edge. I can't remember if there are two pad retainers per pad or just one each.
rotarydave
posted March 04, 2004 10:43 PM
i think i know what you are talking about the little cotter pin/spring thingamabobies. if i remember right there are 2 one each side of the shim, so that would make 4 per side of truck. FYI if you did not already know early 79 rx7s have the same caliper, and Jeff i know where there are 4 of those Rx7s in our area in salvage yards
posted March 05, 2004 11:29 AM
Thanks for the info. Hopefully I won't need to swap calipers. I have two sets of brake pads to choose from. Raybestos and Napa brand. I'll choose the set that has a cut from top to bottom. I think they work better.
I hate to fire up the engine just to shut if off. Maybe I'll just let it sit and idle before I move it into the driveway? Driving wihout brakes should be fun.
posted March 05, 2004 05:47 PM
Driving without brakes WAS fun. :) The pad swap went flawlessly, and the brakes feel great.
I guess I don't believe in turning rotors. It tends to make them thin quickly. What so you guys think?
rotarydave
posted March 05, 2004 07:20 PM
well if i remember they are not all that thick to begin with and also really hard to find good ones, so i would have to agree with you. I am going to change mine this weekend as well, had to take off the wheels to look at the suspension stuff might as well do something useful
posted March 05, 2004 11:35 PM
Good idea. The passenger side was already metal to metal. The driver's side was within 1mm of grinding too.
rotarydave
posted March 06, 2004 12:31 AM
i think kathy atkins still knows where to get NOS (well from the original manuf) rotors. i think the company was MOUNTAIN?
posted March 06, 2004 04:25 PM
I have an old rusty set of rotors that I know I'll need to throw onto a truck one of these days. I hope I can stretch out the life of my current ones as long as possible.
So, are pads the same from '74 (REPU) to '80 (RX-7)?
posted March 08, 2004 08:25 AM
I believe...
...so. (But I haven't double-checked...yet...) ;)
posted March 08, 2004 11:18 AM
If I ever get an RX-7 that needs brakes, I'll compare them.
0.021087884902954 seconds processing time
