Index > Suspension > Thread: Front end ?'s!
3rdshiftkustoms
posted January 11, 2004 04:14 PM
Front end ?'s!
Ok I am taking a little different approach to my courier than most, but I am making a road grader out of it!!! AKA laying frame on air ride suspension, custom tube rear frame, etc... I am kinda stuck on the front end. I have the truck completely laid out as far as the stock suspension wil go, and I am still 4 inches off the ground. I know I can cut the upper spring cups back and get it to lay but was wondering if any other spindles may work on this truck, or better yet how about ball joint spacers? Anyone tried those?
Ricky
3rdshiftkustoms@sbcglobal.net
        Click here to send 3rdshiftkustoms an AIM message.
posted January 12, 2004 09:49 AM
Not that I'm aware of.
You might find lots more info pertinent to your desired results at some lowrider-specific site...? Truckin' mag?
You could always go with smaller diameter rims until it drags on the ground...
3rdshiftkustoms
posted January 12, 2004 02:24 PM
Well the idea is I am gonna be running the same diameter equivilent to stock, so the wheel deal is a no. I plan on running a 17 with a 215/40 or 45 whatever comes close to the stock sizes.
I am thinking of cutting the spring pockets completely out and using custom built bag mounts as it is.
Ricky
0.018570184707642 seconds processing time
