Index > Suspension > Thread: any suggestions for leaf springs?
rotarypwrd
posted June 03, 2003 12:02 PM
wanting to replace old rear leaf springs?
any suggestions or cheap $$$ places to go to have new ones made? upgrade suggesstions?
rotarypwrd
posted June 03, 2003 01:59 PM
only reason i'd replace the leaf spring:
1. bent, cracked, sagging, or otherwise damaged or overly worn. this rare
2. change the spring rate.
3. raise or lower
otherwise it's not worth the time or $ to do it. just inspect the leafs and reinstall!
as it turns out just yesterday I used the angle grinder and wire wheel to remove all paint and rust from both leaf springs. neutralized rust inbetween leafs using Metal Ready. tonite they get primer and they'll be epoxy painted, flex rubber undercoated, and installed with new stock rubber bushings this sunday!
Busy little bee I be.
0.013175964355469 seconds processing time
