Index > Suspension > Thread: New front coilover option
AZosian
posted June 25, 2015 11:23 PM
Soooo if front shocks from the 67-76 F-Body work with very minimal modifications, then why don't we just use coilovers for the same application for our trucks?
AZosian
posted June 25, 2015 11:38 PM
And if you can weld a fish plate on the lower control arm, then drill a shock hole and two mounting holes, you technically could use any coil over with a lower T-Bar mounting setup.
0.013782024383545 seconds processing time
