I know most people cut springs or use the coilovers offered here.
I know that by cutting springs makes it more of an uncomfortable ride especially if you try going real low.
I have no experience with the coilovers since I never been on a repu with them installed.
So I have read somewhere of people modifying there lower control arm,deepening the coil spring pocket so that it lowers the truck without sacrificing ride quality...is that a good idea or bad idea?if its a good idea I'm willing to try this out and use my truck as the guinea pig.seems as though a lot of guys with mini trucks or even full size trucks do this or buy aftermarket control arms that offer that.
quote:I know most people cut springs or use the coilovers offered here.
What are you guy,s thought on this.
It's been done and you get to keep the stock a-arm angles, suspension travel length, tie rod height and geometry overall. But no adjust-ability, and ground clearance decreases.
