Thread: Clicky-Clack Brakes
posted January 11, 2011 10:13 AM |
Clicky-Clack Brakes
Hey all,
one long standing issue I've had with the truck is the front brakes making a clicky-clack sound when moving. It increases with speed, and seems to come from both the left and right side in alternating fashion. I suspect the PO replaced the brakes and didn't put a pin or spring back in. Does anyone have a set of these, no local shop has a clue... or does anyone have a clue on what else could be causing the noise?
I'm The Admin, thats why!
posted January 11, 2011 11:52 AM |
make sure lugs nuts are tight
posted January 11, 2011 11:57 AM |
One more thing... the sound immediately stops when I touch the brakes, so I don't think it's the lug nuts. Plus I've had the wheels off a number of times.
Rotary_Pickup
posted January 11, 2011 06:25 PM |
quote: One more thing... the sound immediately stops when I touch the brakes, so I don't think it's the lug nuts. Plus I've had the wheels off a number of times.
Does it have the brake pad shims installed?
85 GSL
77 REPU (1/1/2004)
75 REPU (7/10/2004)
posted January 12, 2011 03:33 AM |
I am pretty sure I have a hardware spring kit if ya decide ya need one.
bruce toski
posted February 09, 2011 09:26 AM |
Install a new brake hardware kit with the spring that causes both pads to expand. And the shiny metal things that hold the pad to the brackets.
If the metal shims that go between the caliper and bracket are worn then the caliper will rattle. Anyone have a part number for these?
Lastly, installing the anti-squeak plates onto the pads is supposed to REALLY help with squeak and squeal. I'm doing that this week as it turns out. Never knew they are taped to the pads, I've always had ones that pop off.
posted December 19, 2011 11:57 AM |
Missing Shims
Hey Guys,
Does anyone have a set of (what I believe are missing) shims on the front brakes?
posted December 19, 2011 12:03 PM |
RAYBESTOS Part # H15536A Professional Grade
Category: Disc Brake Hardware Kit Is the whole hardware kit. Doesn't include the pad backing plates
http://rockauto.com/
posted December 19, 2011 12:50 PM |
Thanks Brad, I have that kit and the shims, what I don't have is the piece that sits in that cut-out, to prevent the pads from moving up and down, thus causing the click clack sound.
These are the photos of the two kits from RockAuto,
This is the kit for the RX-8, I'm looking for those little metal 'hardware' shims/clips/thingies that hold the pad in place rotationally..
posted December 19, 2011 02:00 PM |
Hi Dan,
Yeah my bad, haven't had my 2nd cup of coffee yet. In order to get those clips you have to order a caliper with the bracket. Rockauto sells it, Raybestos brand for $48 with a $10 core.
RAYBESTOS Part # FRC3280 Friction Ready - Pads Not Included, Remanufactured; Professional Grade; Bore Size=2.12" Inlet Thread=M10X1 Bleeder Thread=M7X1
Contains Bracket; Front Left
$38.79 $10.00 $48.79
Add Part
RAYBESTOS Part # FRC3279 Friction Ready - Pads Not Included, Remanufactured; Professional Grade; Bore Size=2.12" Inlet Thread=M10X1 Bleeder Thread=M7X1
Contains Bracket; Front Right
posted December 19, 2011 06:10 PM |
posted April 19, 2012 04:52 PM |
Amazon Prime
Found out if you take the part number from RockAuto and paste it into Amazon, they typically have the part. In the case of these callipers, they did, it was cheaper by a few bucks, and free shipping (since I have Prime)
posted March 04, 2013 10:20 PM |
