Thread: front wheel bearing
repu74
posted July 13, 2008 07:26 PM |
front wheel bearing
Hearing a squeal from the front, Wheel bearings I suppose. Does anyone know if the inner wheel bearing is the same as the outter wheel bearing? Does anyone have a part number or know where or how to get them or are they a match of something else? Or is the squeal I hear something else? Any help would be appreciated. thanks
posted July 14, 2008 08:12 AM |
the bearings are different
you can get them from rockauto.com, autozone.com, napaonline.com, kragen.com, etc..........
repu74
posted July 14, 2008 09:22 AM |
Thanks Brad. I appreciate it
Klaus45
On two wheels
posted July 14, 2008 11:49 AM |
Squeal...
...could also be brakes. Hard to say from a distance...
Worth noting, though, that the last time either brakes or wheel bearings were serviced (whether properly or otherwise) was also most likely the last time the other component (either brakes, or bearings) were inspected or serviced, as well...
