Thread: stripped control arm bolt!
ratboy
posted May 07, 2008 07:07 AM |
So I found my first real problem with my repu. I was under the truck and noticed the drivers side lower control arm bolt was loose. I went to tighten it but immediatly recognized both the bolt and nut were stripped. I going to try and find a replacement castle nut today since it looks like I may be able to get it down to the good threads (about 1/2" is messed up). I thought it was just a long bolt but it has a collar at one end that bolts to the control arm and a single bolt through the middle of the "bolt" at the other end. I dont have a picture of it removed because once I pull it out Im going to have to compress the springs and I want the truck movable until I goto replace the part. So here are my questions:
1) What is this part called? Im calling it a control arm bolt but its not a simple bolt?
2) I know they made changes to the 77 suspension from earlier models. Am I looking at a 77 only part? Any suggestions for other similar vehicles that may have this same part?
3) Anyone have a 77 parts truck with a drivers side control arm bolt thats good?
Front side of control arm bolt (good threads).
Back side (stripped) of control arm bolt.
1985 Mazda Rx7 GSLSE
1977 REPU
posted May 07, 2008 08:19 AM |
LOWER control arm shaft
Replaced mine here:
http://mazdarepu.com/board/viewthread.php3?FID=8&TID=1698
It's a mazda part. Be sure to put in new bushings. MOOG sells them. You can also buy new castle nuts from thenuttycompany.com
ratboy
posted May 07, 2008 08:24 AM |
Sweet! I was a bit worried there for a bit. I found some on rockauto.com but the picture looks a bit different that what your thread shows (and what mine looks like). The ones I saw had single holes on both ends where ours have a double bolt end. Im gonna call hoping the stock image just doesnt match. thanks alot!
1977 REPU
posted May 07, 2008 10:40 AM |
quote: Sweet! I was a bit worried there for a bit. I found some on rockauto.com but the picture looks a bit different that what your thread shows (and what mine looks like). The ones I saw had single holes on both ends where ours have a double bolt end. Im gonna call hoping the stock image just doesnt match. thanks alot!
That is the upper control rod.
You can also buy a die and run the die over the threads to clean them up.
ratboy
posted May 07, 2008 10:51 AM |
ahh good catch I didnt notice that. I dont see the lower control arm listed on rockauto so I'll give them a call and then look elsewhere if that doesnt pan out. thanks !
1977 REPU
ratboy
posted May 07, 2008 10:59 AM |
Well it looks like rock auto no longer carries the lower control shaft so Im going to keep looking. I'll even try Mazda!
Do you still have your old one Brad? If so and the threads are still good let me know!
thanks ---
1977 REPU
posted May 07, 2008 11:54 AM |
My old one is toast, just buy a new one from MAZDA.
ratboy
posted May 07, 2008 01:33 PM |
Both mazda and ford were worthless as far as looking up let alone finding old parts for this truck (or the courier).
Anyone have any other resources for parts for my truck? Parts trucks? If not Im going to start looking into repairing it as best I can...
1977 REPU
posted May 07, 2008 01:56 PM |
Edited By: Klaus44 on 7 May 2008 14:03
Mazda Part #'s:
0223 34 411 Shaft, Upper Arm; Q'ty: 2
0603 34 416 Bolt, Upper Arm Shaft; Q'ty: 4
99921 1200 Nut; Q'ty: 4
99971 1200 Washer, Spring; Q'ty: 4
--You may have some success with a VIN#-specific parts search, provided you can locate a helpful Mazda Parts manager willing to pursue this... it has been possible to get parts from Japan this way on occasion in the past...
--or--
MOOG Upper Control Arm Shaft Kit #K9154 (One needed per side).
--Wherever MOOG aftermarket suspension parts are sold...(?)
(Courtesy of Ken (nwaco)'s fine thread of approx. 4 years ago -- Thanks, Ken!)
(Say, what ever happened to Ken???)
Original thread from 2004: http://www.mazdarepu.com/board/viewthread.php3?FID=1&TID=879
posted May 07, 2008 02:02 PM |
They're the same for all years, far as info. I have available.
ratboy
posted May 07, 2008 02:17 PM |
That is a great thread with all the part numbers -> bookmarked! I did manage to get a part # out of the guy from mazda but no luck so far finding the actual part.
Mazda lower control arm shaft - # 3874-34-431
I guess this is the joy of owning a 30 year old vehicle that was only made for 4 years in low numbers. By comparison, this makes my GSLSE seem like a breeze to find parts for!
thanks --Erik
1977 REPU
posted May 07, 2008 02:29 PM |
Ah, crap!
How did I manage to transpose 'lower' into 'upper'? D'oh!
...let me know if you need Mazda part #'s for any of the lower bits...
Best, K.
posted May 07, 2008 02:31 PM |
I must've been looking at this post, or sum'thin'...
ratboy
posted May 07, 2008 02:34 PM |
Im quite sure if I needed the upper control arm shaft, I would only be able to find the lower. What did they make 1 lower shaft for every 10 uppers they made?!?!
1977 REPU
VintageMazda
posted May 07, 2008 06:14 PM |
I have the lower control arm shaft. They cost $141.65 new from the dealer. I'll sell it for $160 shipped and insured.
My Middle Name is Japan.
ratboy
posted May 08, 2008 09:05 AM |
vintagemazda -- you have PM...
1977 REPU
ratboy
posted May 08, 2008 07:26 PM |
It looks like I found a parts truck locally but Im waiting on confirmation that the shafts are still good. I may end up with a whole truck though (-engine/trans) so I will let everyone know if Im really that crazy!
thanks everyone
1977 REPU
posted May 09, 2008 10:34 AM |
You're not 'crazy'...
...until you have three or more REPU's... ;b
