Thread: Need A-arm Bushings
RotaryRob
posted March 13, 2006 09:55 AM |
Need A-arm Bushings
I am in need of bushings for my lower control arms. Anyone have a suggestion(s) for a source and / or maybe even a part number? HELP would be appreciated!
Rob
'77 RPU
'75 RPU (V-6)
'76 Courier
Rotary Sprite (3 - 2 project)
'85 IT 7
EP '85 Rx7 (in progress)
'85 GSLSE (4)
C6 Corvette Roadster
posted March 13, 2006 03:45 PM |
Edited By: klaus42 on 13 Mar 2006 15:48
Bush, Rubber -- Lower Spindle :
Part Number: 0193 34 820 Q'ty: 4
...you might try a 'VIN-specific' search with your friendly local Mazda parts man making the call to Japan, if otherwise unavailable.
Let me know if you can get 'em, and if they're cheep, get me a set, too, please!
Alternate idea: Source the courier version part #, and start calling the 'obsolete' Ford parts houses across the country...
posted March 13, 2006 04:35 PM |
Getting ready to redo my front suspension on the repu. What do you think about polyuerathane bushings for the control arms. I haven't been able to find any. If someone has located these respond and let me know ehre to buy them. Thanks.
posted March 13, 2006 05:51 PM |
MOOG makes LCA bushings
there were part #'s posted here a while back.
also try carparts.com or kragen.com
RotaryRob
posted March 14, 2006 10:02 AM |
THANKS a bunch guys for the help! I'll let you know what I dig up.
'77 RPU
'75 RPU (V-6)
'76 Courier
'85 IT 7
'85 GSLSE (4)
bwaits
posted March 15, 2006 06:06 AM |
http://www.oreillyauto.com/EW3/ByKeyword.do?keyword=suspension&descriptionId=1465
This is where I got my lower control arm bushings as well as the upper cross shaft.
I think you can order online and have them shipped to you.
If not, let me know and I can pick them up locally.
-billy
ReSpeed Online Catalog
RotaryRob
posted March 30, 2006 09:39 AM |
Thanks Guys,
Took Billy's advice and picked up a couple pair from O'Reilly's. About $20 a pair. BUT, replacing those things is a real PAIN..... especially without the proper spring compressor. I still don't know how to press the new ones into the A-arm without damaging the outer face rubber. I ended up grinding off the "bumps" on the OD that insure a TIGHT fit so I could get them in with a reasonable press. Getting the old ones out and off the shaft was no picnic either. Anyway, thanks for the assist.
Rob
'77 RPU
'75 RPU (V-6)
'76 Courier
'85 IT 7
'85 GSLSE (4)
posted March 30, 2006 03:15 PM |
Bushing replacement
Not looking forward to doing this job.
Everyone has had a tought time of it.
The REPU and the Courier manuals suck.
No mention of the proper way to do this.
argh .... the insanity .....
Bruce Toski
bwaits
posted April 13, 2006 06:09 AM |
When I did mine I lost allot of sweat, tears and blood. Screaming curse words. Cut my finger open with a brand new razor blade. Passed out. Seriously! This was just the task of removing the old bushings!
I tried to press the new ones in and got no where but a half pressed bushing and the center torn out of another.
I ended up dropping them off at the local auto machine shop and picked them up 2 hours later and paid $25. Best $25 I have ever spent in my life.
-billy
posted November 07, 2006 03:47 PM |
For those in the Greater Los Angeles Metropolitan area
The company below installed the LCA bushings and did a great job. $10.00 for one a-arm. They finished the bushing pressing that another shop could not. Did it on the spot no appointment in 15 minutes.
Said the trick was to put a fork under the a-arm ear, where the bushing squeezes into.
City Industrial Tool & Die
25524 Frampton Ave
Harbor City CA 90710
310.530.1234
