Thread: front springs
julian1
posted January 16, 2006 09:46 PM |
front springs
any one knw if mazda b1600 springs are the same as repu?
previous owner has cut springs too far
repu1977
posted January 17, 2006 04:42 PM |
Edited By: repu1977 on 17 Jan 2006 16:47
actually they are not :(
the Repu springs are larger in thickness and stronger in spring.
but you can use them since the size (height and circuar diamiter) is the same.
hope this helps.
77 REPU "Yellow"
82 380SL
93 f250 4X4 turbo Diesel
66 Benelli
94 740 IL
posted January 17, 2006 06:21 PM |
Coil Overs
Brad can make you a set of coil overs, at their highest, it is near stock ride level. At the lowest, there is still an ok amount of tire clearance
I'm The Admin, thats why!
julian1
posted January 17, 2006 09:59 PM |
thanks for that
any idea how much for coil overs?
also im in newzealand,i will check but think it will have to be certed for coil overs here.
can get after market king springs here for b1600 standard height only,cheap tho.
i hav one of two repus in newzealand so not many parts available here.
cheers julian
posted January 18, 2006 08:49 AM |
Edited By: klaus42 on 18 Jan 2006 08:49
I think there's a thread here...
...in this very section, by Brad, about his coilovers... (I believe they were offered at $400 US, prior to shipping costs...?)
Some years Ford Courier springs may, or may not, be a more exact stock replacement, or at least a functional alternative...
