Index > Trucks or Parts WANTED > Thread: wanted: front spindle and brake assembly
posted December 17, 2003 09:18 PM
to research a big brake kit
i'm looking to buy:
spindle
hub
rotor
both bearings
grease seal
brake caliper bracket
caliper
castle nut
all from the same side of vehicle of course!
posted December 18, 2003 07:25 AM
Close Match
I'm using the frontend of the 84 B2000 on mine. The upper and lower A-arms bolt right onto the 74 frame. Ball joints are different but easier to find. Brake pads are the same as RETU and RX-7. Good luck finding someone to let go of a 74 assembly. But if you don't find one look at the 78-84 B2000's or Couriers.
Charles
posted December 18, 2003 02:21 PM
doesn't the b2000
have solid disc front brakes and not vented?
0.020752906799316 seconds processing time
