Thread: charcoal cannister
posted July 20, 2003 10:15 PM |
charcoal cannister
Want to buy a charcoal cannister, you know the one in the bed that fuel tank vents into.
74
posted July 20, 2003 11:11 PM |
I have one 'extra'...
...but it's from a very early model '74, and it's not the cleanest anymore... lived for some time without the cover, and I might snap those rusty bolts if/when I go to pull it... lemme know...
posted July 21, 2003 11:11 AM |
has the fuel lines been hooked up to it during it's life?
is it usable?
Thanks Klaus,
posted July 21, 2003 01:17 PM |
It's likely been years since
anything's been hooked up to it... usable: perhaps... (if the rusty spots on the bottom aren't too far into it, or if you're up for restoring it prior to use...).
posted July 21, 2003 02:49 PM |
mabye not.... looking for plug and play
posted July 21, 2003 05:53 PM |
You need it to pass emissions?
I could only guess that either just about any would do, or you actually need a NOS/restored and re-charcoaled one...
There's not too much to these can's, is there? What happens to a used one that is disconnected, and sits and weathers/bakes in the sun...does that revive the used charcoal? Just got me thinking...
posted July 24, 2003 09:15 PM |
Does anyone have one WITH charcoal????
When I was working on them on my trucks, and had them out, It was empty. I looked it up and it was labeled a "condensation" tank. That implies to me that it is a hollow tank to drain off condendsation from the fuel. I believe it also relieves fuel pressure as well to prevent vapor lock. Just my two cents worth, but I have six trucks and none have "charcoal". I think the seventies were a bit before the "charcoal" revolution in pollution control.
posted July 24, 2003 09:24 PM |
Charcoal cannister
The device on the left front of the bed is really a condense tank only ( no charcoal), the real charcoal cannister is located under the dome shaped piece on the bottom side of the air cleaner cover.
posted July 25, 2003 08:49 AM |
I'm tempted to make a joke about
a rotary charcoal grille--but I'm not running the stock air filter setup!
posted July 25, 2003 10:37 AM |
in that case
I'll just drain mine out. pour some MetalReady in there to derust and dry it.
posted August 05, 2003 08:52 PM |
how much?
for the condense tank?
posted August 06, 2003 08:39 AM |
Who, me? Mine?
I'm about to be outta here on biz. for a few days--back by Tuesday 8/12--can we deal with it then? Would $20 + cost of FedEx be about right? (I hope I don't find it's rusted thru at the bottom after I pull it...!) You can email me, but keep it 'small', as my hotmail account is overflowing... I'll let you 'reassemble' the address, so as to foil those webcrawling spambots...(time for a new email address for yours truly...) klausdp at hotmail dot com . Or, can I give you a call upon my return?
posted August 06, 2003 09:23 PM |
sent email
sure we can deal with it after 8/12, have a good trip!
posted August 22, 2003 09:45 AM |
Didn't mean to blow you off since the 12th... been super busy with work; will forseeable continue to be... I'll try to get on it--let me know. Thanks, K.
posted August 22, 2003 08:08 PM |
Still interested Klaus
Sent private mail to you. Thanks.
