Thread: WTB need a 1977 3rd member
bosozoku
posted March 17, 2011 04:28 PM |
i still have the OG 4speed in my 1974 and would like something better for freeway cruzing.
located in Torrance, CA USA.
thanks
mattraver
posted March 17, 2011 11:01 PM |
posted March 18, 2011 02:44 PM |
77' came with a 3:90. I have one in my 74' and it cruises nice on the freeway.
bosozoku
posted March 18, 2011 06:20 PM |
quote: 77' came with a 3:90. I have one in my 74' and it cruises nice on the freeway.
do you have a 5-speed too?
mattraver
posted March 19, 2011 03:34 PM |
no 5 speed but find a 79-80 rx7 trans dont have to cut the tunnel , or an rx8 trans and pinapple racing has te conversion parts ,a little pricy though
posted March 19, 2011 09:07 PM |
Yep, 77' ribcase 5-speed.
posted March 23, 2011 10:45 PM |
trans parts
Very recently found out that a B2200 86 to whenever the body changed again rear tail shaft housing and shift linkage will fit a FC or FB RX7 trans as long as its not series 5 89-91 RX7 trans. Then you don't have to cut the shift tunnel. 5 speeds galore.
Hope this helps someone.
posted March 23, 2011 10:48 PM |
rear options
Another note, B2000 rear ends up to 1984 used the same center chunk, giving you more options on gears, while being a little higher, but for highway crusing, its not a problem.
bosozoku
posted March 24, 2011 03:57 AM |
Thanks for the GREAT INFO!!!
Klaus42
posted March 24, 2011 12:20 PM |
*NICE!*
quote: Very recently found out that a B2200 86 to whenever the body changed again rear tail shaft housing and shift linkage will fit a FC or FB RX7 trans as long as its not series 5 89-91 RX7 trans. Then you don't have to cut the shift tunnel. 5 speeds galore.
quote: Another note, B2000 rear ends up to 1984 used the same center chunk, giving you more options on gears, while being a little higher, but for highway crusing, its not a problem.
Thanks, Charles!!!
That info. deserves its own thread in the Engine/Drivetrain section, IMHO.
bosozoku
posted March 24, 2011 01:43 PM |
so to make the S4 tranny work the only other change would be to use a S4 starter too?
posted March 24, 2011 03:57 PM |
starter
Any 1st gen, or second gen starter will work as long as its not a t2. 2nd gen starters are gear driven and just sound different. 1st gen starters have a threaded hole at the top, where 2nd gen starters need a longer bolt and nut to hold them on. Hope this helps.
Charles
