Thread: 4.6 gears wanted for repu
micah
posted July 06, 2007 06:50 PM |
I need the gears off a manual repu
posted July 06, 2007 07:32 PM |
Dude, the 4.62 is going to suck unless you plan on taking it to the drag strip. 1st gear will be useless.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
posted July 07, 2007 12:06 AM |
Edited By: Klaus44 on 7 Jul 2007 00:08
Indeed.
If anything, you'll need the taller rearend from the '77 to even begin to take advantage of what a bridgeport has to offer... provided it was properly built to turn the kind of RPM's that B-ports make their best power in. Hope your rotors were 'race clearanced', your stationary gears hardened, etc., etc., etc.
You'll want AmsOil gear lube in your trans. and rearend for sure. You may also want to run a synthetic in your engine, once broken in...
BTW, you may find that collecting your 'long primary' exhaust prior to a megaphone/muffler at the very tail end will yield superior results to any 'full dual' setup.
posted July 07, 2007 09:38 AM |
Go for the 3.90 rear end from a 77.
posted July 09, 2007 03:09 PM |
Wanted 4.62 diff
I think I can get you one for $300 plus $40 for shipping
Bruce Toski
954 583-4191
