Index > Trucks or Parts WANTED > Thread: REPU Transmission Wanted
JJOYCE
posted June 05, 2002 07:46 AM
Seeking REPU transmission -- complete, want case in good shape.
Let me know if you have one
John Joyce
Tulsa, OK
918/573-7901
918/638-4059
john.m.joyce@williams.com
posted June 10, 2002 09:52 AM
Could you be more specific?
Automatic, 4-speed, or 5-speed? For what year, preferably? Do you need a clutch as well?
JJOYCE
posted June 10, 2002 11:20 AM
I am interested in a 4-speed -- am presuming it will bolt to 86 13B regardless of the year of the truck it came from (is this a safe assumption)?
Are the 4 speed ratios the same as 1 through 4 on a 5-speed?
Regarding the clutch, I am planning to put a "quartermaster" style cluthc/flywheel unit on it. I think I might need the starter ring gear (especially if it is a different diameter than 1st gen RX7) Are there any other clutch compatability issues I should be aware of?
What kind of money would you want for a 4-speed (presuming you have one)?
Are parts for these gearboxes readily available through Mazda, Mazda Competition, etc?
Thanks for any advice you can give!!
John Joyce
posted June 11, 2002 10:25 AM
John:
As far as I know, all the transmissions' bellhousings have the same bolt pattern. However, your clutches and flywheels do differ: rotary pickups had the heaviest stock flywheels at 33 lbs., for example, and the clutch has 9 bolts, as opposed to the 6 on the closest match after that, which would be rx-4... unknown to me how interchangeable 2nd-gen rx-7 stuff is... Your REPU 4-speed did not have the same ratios as 1-4 on a 5-speed... and those ratios changed somewhat with year and model as well, apparently... Racing Beat I believe has the info on what year/model had what gearing... I have a list of what years came with what flywheels, courtesy of spuds... What is a "quartermaster" clutch? 4-puck?
Sorry, I don't have any 4-speed trannys, for sale or otherwise...REPU 4-speeds seem to be quite the rarity out there...I'm running 1st-gen rx-7 and rx-4 wagon 5-speeds.
Hope this helps! --K.
posted June 11, 2002 04:11 PM
I have this page bookmarked, its a good reference:
http://mrmazda.members.atlantic.net/tranchrt.txt
0.021522998809814 seconds processing time
