Thread: I need a new rear wheel cylinder
ScottyG
posted May 04, 2004 07:27 PM |
I need a new rear wheel cylinder for my 74 Repu.
The part number is Wagner# F100751 (R.H. side).
Local parts house tried to order it and Wagner has discontinued it. The L.H. side # F100750 is still available.
I tried three different francise parts houses and a search of their warehouse came up empty.
Any other options? Help a Repu brutha please.
posted May 06, 2004 12:29 PM |
Obsolete parts dealers...
There's a few that regularly sell on ebaymotors... just a question of when which part shows up. You might try searching completed auctions, and contacting the sellers...
ScottyG
posted May 06, 2004 05:16 PM |
Here's the deal......
The two different part #'s are just mirror images of each other. The brake adjuster arm screws into the casting and can be swapped to the other side along with the matching piston.
I have an N.O.S. of each number -- the actual markings and casting numbers are identical on the base castings. I just got two of the available F100750's and I'll just convert one over to an equivalent of the F100751 unit to fit the other position.
posted May 26, 2004 07:07 AM |
Wheel cylinder specs
Scotty G,
My 1974 Technical Data book says that the ID of the REPU rear wheel cylinders should be / was 3/4" or 19.05mm.
The info I have for the Wagner cylinders you mentioned is:
WAGNER
Rear Wheel/Cylinder-Left
13/16", F100750, 74-76
Rear Wheel/Cylinder-Right
13/16", F100751, 74-76
(thanks to NWACO for this info)
The same technical data book indicates an ID bore of 13/16"for the 1974 B1600 and B1800.
I would have to get out my hydraulic "basics" book to tell you how this would affect your braking. It may be inconsequential, I am not sure.
Just thought you might like a "heads up" on this.
Best Regards,
Bruce Toski
Bruce Toski
Mazda Certifications, Master ASE Certification - Former Auto Vo-Tech instructor, A+ Computer Certified
(Former owner of R100, RX-3, RX-2, RX-4, Cosmo, NSU RO80 engine, Sachs Wankel chainsaw, Sach Motocross prototype motorcycle, Graupner radio control airplane engine,84 RX-7 SE, Hercules W2000 Wankel motorcycle, Suzuki RE-5 Wankel motorcycle)
(Have left: 1974 Mazda REPU, OMC snowmobile wankel engine, SAVKEL wankel ultralight engine)
Also own a 1972 and 73 Audi 100LS, 1991 Audi 100 and a 1986 Audi 5000S. Wife owns a 93 Toyota Celica
2361 SW 36th Terrace
Fort Lauderdale, FL 33312-4291
954 583-4191
chk my auctions:
http://cgi6.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewSellersOtherItems&userid=btoski
