For sale I have a new-in-box aluminum 3-row 4-pass radiator. It is designed for an RX-4 but fits the REPU fine. You'll need to drill mounting holes in the mounting flanges of the radiator, and fiddle with the oil cooler brackets to get it to fit a REPU.
Why is it so cheap? Because it isn't perfectly flat. It appears that it was welded together crooked, or the heat of welding warped the core ever so slightly. One side sat flush on the core support of my truck, and the other side had about a 1/4" gap. I don't believe this will impact actual functionality of the radiator.
This is the same radiator that is listed all over eBay for $135+
quote:For sale I have a new-in-box aluminum 3-row 4-pass radiator. It is designed for an RX-4 but fits the REPU fine. You'll need to drill mounting holes in the mounting flanges of the radiator, and fiddle with the oil cooler brackets to get it to fit a REPU.
That's the exact one I got and have no issue with! Perfect fit!
