posted December 14, 2015 08:00 PM |
Edited By: nwaco on 14 Dec 2015 20:05
Parts for sale
Hi Guys, Its been a while. I am clearing out some parts and hopefully help some of you guys out.
I tried to move a lot of stuff earlier this year as I was moving. I got moved and now I need to move some more stuff.
I have the following for sale:
Hoods. Nice, decent. $50 each. (Pick up only)
Drivers door, decent, no hinges. $50. (Pickup only)
Door window glass. Either side, $25 each
Door window frames, Either side. $20 each (Pickup only)
Front wheel hubs, $45 each
Front control arms, upper or lower, left or right, $50 each
Steering center links, $75 each
Transmission crossmember, $25 each
Front engine cover/engine mounts, $40 each
Cab Heater assemblies, $100 each
Cab heater hoses, $25 each, $40 set
Oil coolers, $50 each
Under hood wiper motor/arm assemblies, $75 each
Decent front valance, $125
Fan control assembly with cables and knobs, $50 each
Dirty intake manifolds, original, $25 each
Speedometer cables, $25 each
Hood release assemblies/cables/latch release, $50 set
Steering column trim, $25 each
Battery box assemblies, $75 - $125 each, depending on condition.
Clutch or gas pedal assemblies, $25 each
Handbrake release assemblies, $40 each
Front bumper steel mounts, $30 set, $20 each
Marker lights, complete, $40 each
Tail light lenses, $25 each
Complete Tail light assemblies, with trim rings, $50 each
Underbody heat shields, $25 each.
Fan surround plastic, $25 set.
Fluid bottles, $20 each
Fresh air boxes, $30 each
Electrical control boxes, $50 each
Large, under-hood āLā? shaped heater pipe, $30 each
Water heater housing, $40 each
Original, unmolested, 4 port, engine cores, $200 each (pickup only)
Gage assemblies, complete $100 each
ā1977ā? drive shaft, $40 (Pickup only)
Shipping is in addition to prices listed. These are the parts I am working through right now. I possibly have other parts available, please inquire if you have additional or specific needs. I may have them available as well. Thanks
