Index > Trucks for Sale > Thread: 74' Supercharged V8 REPU 500hp
dpassmore
posted June 09, 2014 07:03 AM
Located in Alabama
1974 Mazda REPU Hard Top Convertible Truck
Hot Rod Black/Flat Black painted in 2011.
Fast does not even begin to describe this truck.
Powered by a Supercharged 350 small block. Engine is a 97 4 bolt main 350, aluminum TRICK FLOW heads, with a Comp Cams hydraulic roller cam with roller rockers comp cams pushrods, topped off with a polished Weiand 177 supercharger, and a race Demon 750 double pumper.Over $2900.00 invested in carb and blower alone. Aluminum radiator keeps it cool enough to drive in 100 degree traffic.
Trans is a 700R4 with B&M transpak,7 qt. pan with cooling tubes, and a B&M trans cooler connected with metal lines. Shifted by a B&M Bandit shifter.
The rear end is a 8.2 10 bolt 3.08 with Auburn posi unit. Rear suspension is a fabricated ladder bar with QA-1 adjustable coil over shocks.
Steering is a SWEET manufacturing rack and pinion. With Heim joint tie rods. The wheels are Centerline Corona.
The interior has Driver FX racing seats Matrix 4 point harnesses, auto meter gauges in the fabricated console that runs from under dash to behind seats. Carpet is accented by diamond plate floor mats. Custom covered dash and door panels interior is 80% finished.
The roof is attached with aircraft latches and is easily removed.
Photo album here:
http://passmore.zenfolio.com/p266632055
dpassmore
posted June 09, 2014 07:07 AM
Sorry, price is $6800. Email is:passmoreautomotive@yahoo.com
0.014963150024414 seconds processing time
