mazdamcd
posted July 01, 2013 11:59 PM |
1975 Portland Oregon
Selling my 75 truck. has 13B GSLSE fuel injected motor, 5 speed trans, Aluminum fuel tank, New apholstered seat. Comes with existing wheels plus a good set of studded snow tires mounted to B2200 rims. Truck starts and runs strong. Needs some tuning to eliminate slight idle bounce.
Don't know much about the trucks history but was told the motor is fairly fresh and has heavy duty water seals.
Good generally straight body overall with very minimal rust spots. Has a small hole in driver side floor pan and looks like someone patched small areas of the fenders at some point. Dash shows the typical signs of previous cracking and someone apparently put caulking in the cracks in preparation to re skin the dash which was never done. there are no door panels on the interior, but the headliner looks decent. Current muffler is only loosely mounted as a test pipe to keep noise at a minimum.
Truck has no title so one must be obtained by applying for a new title.
pics here
http://portland.craigslist.org/wsc/cto/3908695443.html
$2,800 call 503-396-9806 with any questions.
