Thread: heater control valve
rotorsport
posted March 05, 2014 12:50 PM |
my 76 repu heater control valve is leaking does anyone know where I can get one or does any one have one atkins too expensive and I haven't seen a listing on e bay or there sight need help thanks guys.
[URL=http://s1310.photobucket.com/user/rotorsport72/media/IMAG1845_zpsce2f0471.jpg.html][/URL]
mazdarx605
posted March 05, 2014 01:47 PM |
I bought one from Atkins a few months ago. The first one he sent was the wrong part, and with a little prodding,and some emails back and forth I finally got the right unit. I have yet to install it, but it doesn't appear to be too difficult. I have the cooling system drained down for a intake manifold coolant leak,so I plan to do it soon. Mine isn;t leaking, but rather the heat is always on regardless of the position of the lever. It seems the valve is leaking past when in the closed mode.
rotorsport
posted March 05, 2014 08:40 PM |
yea $100 bucks for a 20/40 dollar parts I don't think so but yea it easy to replace I'm just gonna fad something up for now till I find one I took mines out and just cap off the plunger side for now ill still have a heater I may put a in line manual valve for now ill post some pics.
[URL=http://s1310.photobucket.com/user/rotorsport72/media/GetAttachment_zps5faac5ba.jpg.html][/URL]
rotorsport
posted March 06, 2014 08:45 PM |
top post pic is the problem Im having and temp fix is the bottom pic for now till I can find one.
[URL=http://s1310.photobucket.com/user/rotorsport72/media/rotorpwr/IMAG1845_zpsce2f0471.jpg.html][/URL]
[URL=http://s1310.photobucket.com/user/rotorsport72/media/rotorpwr/GetAttachment_zps5faac5ba.jpg.html][/URL]
Mazdamark
posted March 11, 2014 12:46 PM |
Mazda still has them... I think it was around 50 bucks.... Also, you sometimes see early Courier ones on fleabay... Same part as OEM Mazda, I believe.
94 RX7
89 RX7 GTUs
85 GSLSE
88 323 GTX
1975 REPU
posted March 13, 2014 09:15 AM |
If that valve is leaking and you don't want to spend the bucks, you can just run a hose from the outlet to the inlet on the block, creating a loop. So no coolant enters or exits the cab. Since Spring is around the corner you won't need a heater for long.
Drain the heater core, it's a real fun job.
You can also get a new heater core for $45 but look it up for a Courier. Advanced Auto is where I got mine.
Mazdamark
posted April 10, 2014 12:34 PM |
quote: You can also get a new heater core for $45 but look it up for a Courier. Advanced Auto is where I got mine.
Hey Brad, what year Courier did you use?
94 RX7
89 RX7 GTUs
85 GSLSE
88 323 GTX
1975 REPU
