Thread: Window channels
2 '] |
Xp882
posted December 10, 2011 04:30 PM |
Window channels
Does anyone know if you can still get the door window channel rubber?
posted December 10, 2011 10:04 PM |
Not sure but Courier and B2000 all the way to 1984 are the same if that helps.
hunter
posted December 11, 2011 04:12 AM |
run channel
unfortunately the last batch of run channel I purchased from Mazda turned out to be all rubber instead of felt lined.
Works like shit. Window drags.
Buy generic run channel with felt
tis a simple cross section
TimPA136
posted December 18, 2011 08:17 PM |
all good ideas
Any luck XP882 available locally?
I'll be looking myself tomorrow for the same thing.
TimPA136
posted December 18, 2011 08:25 PM |
Any luck XP882, available locally?
Xp882
posted December 19, 2011 11:57 AM |
Going to check j&j hopefully this weekend
posted December 19, 2011 06:03 PM |
I got mine at J & J. Nice guys and they have everything there. Make sure you take your truck so they can see exactly what you need.
TimPA136
posted December 19, 2011 07:41 PM |
I ordered some overnight locally, I'll let all know ASAP.
TimPA136
posted December 20, 2011 08:54 PM |
I have some channel that is close but slightly fatter.
It can stuff it in the channel, but until this weekend when I can fit it in properly, I won't know If I can recommend this yet.
My part no. is AS137060
Hey Guys, is this the JJ fabrics you recommend ???
http://www.jjautofabrics.com/
I'll update you this weekend when I can determine if it will fit.
Xp882
posted December 21, 2011 06:36 PM |
Yeah they are in Rialto off the 10 n riverside
TimPA136
posted December 29, 2011 09:48 PM |
Edited By: TimPA136 on 29 Dec 2011 21:49
quote: I got mine at J & J. Nice guys and they have everything there. Make sure you take your truck so they can see exactly what you need.
OK thanks Max and Xp882.
I'm not entirely happy with the channel I got elsewhere made to fit the Generals finest in 1965.
I plan to go over there and button up my door trim Sat.
Xp882
posted December 31, 2011 12:11 PM |
As1340 is the item number you need from j&j 16 bucks with tax probably need two if your going to do the complete door all the way down
TimPA136
posted December 31, 2011 02:03 PM |
As1340 is the item number you need from j&j 16 bucks with tax probably need two if your going to do the complete door all the way down .
OK Thanks.
They are giving everybody a well deservrd holiday this
New Years Eve today.
I'll catch them later in January
TimPA136
posted January 07, 2012 12:54 PM |
Got the run channel, too.
Great place, thanks Guys.
top1usa
posted January 10, 2012 09:41 PM |
Can anyone put up some pics of their result? This is great help guys....thanks in advance!
Tim
74' Mazda Repu-Flare
yellow
85' Toyota ae86-Red-SOLD
88' Toyota ae92-Gray
14' Toyota Prius
TimPA136
posted January 29, 2012 02:57 PM |
Can anyone put up some pics of their result? ...thanks in advance!
Tim
Well, no pictures but a hint to soak the channel screws a week in advance. The left side came loose OK but replacing the right side, I will have to chisel out one channel adjuster screw later.
spokanerxdude
Less cubes... More balls
posted January 29, 2012 03:55 PM |
TimPA136
posted February 04, 2012 02:13 PM |
Here are photos more not what to do but hopefully helpful. First to remove the handels is a simple nail if you slipack the spring boot the nails fall right out.
Here is my frozen channel screw
Here I got it out, had to use a little propane, watch your paint.
so far so good, feed the new channel in.
A little gentle persuasion. The black sealer is strip-caulk to seal the outside for wind noise and water.
I chose anti sieze, notice the adjustment area
I sealed it back up with stater bros paper bags and packing tape to protect the inside trim.
top1usa
posted February 04, 2012 10:24 PM |
quote: Here are photos more not what to do but hopefully helpful. First to remove the handels is a simple nail if you slipack the spring boot the nails fall right out.
Thanks for that Tim..that was great help!!
yellow
14' Toyota Prius
remydrm
posted February 22, 2012 11:23 AM |
quote: As1340 is the item number you need from j&j 16 bucks with tax probably need two if your going to do the complete door all the way down
Tim, would you need 2 per door? I think they come in 96inch length pieces...
I'm doing both sides. Would I need to order 4 parts?
Thanks!!!
2 '] |
