BadAssRX-7
posted April 27, 2007 11:48 PM |
74 with bad wiper switch
ok i had no wipers so i started working my way into the system and found that the wiper switch is my issue. i was told the ford courior switch will work... what years swap in to the 74 repu?
Thanks David
i patched the wipers with a set of wires running through the firewall to the motor and installed a cig. plug on the other so if needed i could plug it up and have slow wipers atleast.
