The drivers side window is really sloppy, handle loose, etc.
Anyone have any insight on what other trucks have the same setup? I know OEM is out of the question.
Thanks!
Find a window reg out of a courier or a B2000, or Sundowner up to 1984 is the same. There are plenty of them out here. The only difference may be the window crank, may be different on the newer ones. They can also be fixed by welding a washer on the front and back of the shaft the take out the slop. Good luck, Charles
