Index > Body Exterior > Thread: Parts from mazda B1800 to fit on Repu ???
Lasse
posted September 12, 2003 02:37 PM
I wonder if the cab on B1800 -77 to -84 is the same as the Repu´s... Why i wonder , is that i need to shift the panel there the door hinges is mounted... I have found a new part but it is to a Mazda B1800...
Thanks...
The swed...
straightrepu
posted September 12, 2003 10:22 PM
Edited By: straightrepu on 12 Sep 2003 22:24
Can we help the Swede?
The biggest issue here is if the 72-76 and the 77-84 hinges have the same bolt pattern, the part number and design of the hinges are different but can they be interchanged? Or could you make a hybrid hinge from two donors to make a diffent bolt pattern work or would have to change the whole door shell to make it work? I cannot tell from the mazda parts books. Anybody have any wrecking yard savvy to share?
74 restorepu
0.016116142272949 seconds processing time
