Index > Body Exterior > Thread: Rubber or weather shield kit
tuffs
posted August 25, 2016 05:20 PM
I know this has probably been asked a few times but I am after a weather shield kit for my 1974 REPU. Both front and rear screens and doors. Is the B1600 combatible? Are the kits on EBAY all good, I think for the ford courier? I think 'atomboys' has a complete kit for sale on EBAY. Cheers
1974 Mazda REPU
1985 Mazda RX 7 GSL-SE
1984 Mazda 323
2004 Mazda SP23
posted October 26, 2016 10:48 AM
I use the atomboys door seal on my drivers door. It is thicker than the OEM Mazda one, takes a touch more effort to close the door. But it does seal rather well.
http://www.ebay.com/itm/MAZDA-REPU-B1600-B1800-Rotary-Ford-Courier-PICKUP-DOOR-SEAL-RUBBER-WEATHERSTRIP-/161045815525?vxp=mtr&hash=item257f1420e5
Haven't used any other door seals of theirs so cannot comment.
tuffs
posted October 26, 2016 12:28 PM
Thanks for the reply. I will check that out. Do you know if they also do the quarter window rubbers? Mine are pretty stuffed.
1974 Mazda REPU
1984 Mazda 323
2004 Mazda SP23
posted November 02, 2016 10:39 AM
I don't think so. May need to find some used ones, if they're not ripped you can rejuvenate them with baby oil or Goop hand cleaner.
boyotoyo
posted November 02, 2016 08:27 PM
I had the same result as Brad. I replaced the seal on both doors several years ago with these ones from Thailand.
My passenger side door closes okay, however, my drivers door has never closed well since. Even after years of compressing the rubber I still have to slam the door to get it shut.
Looking for alternatives myself.
For the little quarter windows, you will likely have better results searching for Ford Courier parts. Should be the same.
xp882
posted November 03, 2016 09:21 AM
j & j fabrics in rialto has some nice fitting door seals
0.016124963760376 seconds processing time
