Index > Body Exterior > Thread: spare tire removal
bosozoku
posted June 09, 2014 02:29 PM
spare tire removal
I am having a hard time removing the spare tire. I'm assuming I need to rotate the bar counter clockwise? The first time I tried to remove the wheels I thought I was screwed also.
Mazdamark
posted June 18, 2014 12:08 PM
Yeah, the lug nuts on the truck are quirky... If it bugs you, there are usually auctions for replacement standard thread studs available on ebay for the Ford courier... The OEM Ford ones are actually made by Mazda, but I'm sure the aftermarket ones from doorman and the like are fine as well.
On my truck, to release the spare I turn to the right first to release the ratchet, then it lets you turn to the left to drop the spare. You'll feel or hear a click when turning to the right which I assume is the mechanism that locks the wheel into place releasing.
94 RX7
89 RX7 GTUs
85 GSLSE
88 323 GTX
1975 REPU
posted June 18, 2014 12:32 PM
spare tire
ya need to push the handle IN first, then turn
0.01929497718811 seconds processing time
