Index > Body Exterior > Thread: Keys and locks.
posted April 12, 2010 12:04 PM
Keys and locks.
Has anyone out there replaced their lock cylinders and keys. Getting the truck done and i'd look really stupid opening the drivers door with a screw driver. Need new lock cylinders for ignition switch and doors.
Klaus45
On two wheels
posted April 12, 2010 09:51 PM
Never looked into availability (?) of NOS lock cylinders... (but I do know which local locksmith shop I'd go to for anything short of that.)
wackyracer
posted April 13, 2010 06:55 AM
use solex door locks and if you need the ignition stuff, use a RWD GLC with minor tweaking as it doesnt an extra wire for start relay. if not, LMK and I may have extra stuff from either a RX-2 or RX-3 which are the same shit
posted April 13, 2010 08:43 AM
Thanks Mel, you rock. I'll research the solex locks. As far as igntion, i removed most of my relays including ignition rely. Appreciate the info on the GLC igniton switch. Setting the truck up with a push button start. Thanks also for the help with the weber. The truck sounds wickedly possessed. Using the racing beat t-2 pre-silencer with the Furai muffler.
wackyracer
posted April 13, 2010 09:59 PM
Edited By: wackyracer on 13 Apr 2010 22:01
here ya go
this is the newer style instead of the older barrel or grandfather clock style key.
older style solex in my RX-3s
absolutjh
posted April 14, 2010 12:55 PM
NOS Parts for Courier/REPU
http://seattle.craigslist.org/see/pts/1690615075.html
New replacement parts (NOS) for Ford Courier (1972 - 1982) and Mazda B-Series (1972 - 1984) trucks.
Brake Drums (1972-1984)
Clutch Master Cylinders (1972-1976)
Clutch Slave Cylinder Kits (1972-1975)
Wheel Cylinders (Mix of front/rear/left/right for 1972-1978)
Brake Master Cylinders (1977-1980)
Ball Joints (Lower, 1972-1984)
Distributors (1979-1984)
Fuel Pumps (Electric, 1979-1984)
Ignition Lock Switches w/keys (1972-1981)
Gasket Sets (1972-1984)
Control Arm Shaft Kits (1972-1980)
I had purchased this inventory wholesale several years ago in advance of starting a parts supply business specializing in older small trucks but now I'm going in a new direction so I'm clearing the shelves.
All parts are new and in their original boxes. Email me your truck's model year and I'll send you back a list of the parts I have that will fit. The list will show the quantity I have available of each part as well as an extremely reasonable price for each.
Thanks!
JOSHUA HAYES
1974 REPU, w/ Pineapple
Racing Bridge Port 13B and
RX-7 5 Speed conversion.
2001 BMW E38 740i Sport
0.01763391494751 seconds processing time
